Question about Husqvarna Partner Gas Powered Cut Off Saw K960 16"
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
  • 41 Answers
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Posted on Oct 24, 2010
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
I have a partner k700 was running fine ,and now no spark. any ideas
sounds like the coil went bad or the kill switch wire grounded out
Jun 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Mower start fine. Runs for 20 min or so and then runs ruff and shuts down. Restarts fine and shuts down appr. 5 mins later. Has new spark plug,air filter, fuel filter and more than enough gas.
It's one of two things. My first thought is that you have a clogged gas cap. Try loosening it when the mower starts to run ruff. If it smooths out again and runs fine, then you know that the carburetor is not venting properly. Either buy a new gas cap or clear the breathing holes in the cap, if possible.
The only other thing it can be is that your Ignition Coil is going bad. A bad Coil, once it gets hot, will shut down. But it usually takes longer than 5 minutes for them to cool down well enough to start back up.
My Vote is the cap!
Good Luck!
Jim
Aug 18, 2011 | Poulan Garden
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
2004 ford f150 ranger shuts off during operation tach stays up arround 2000 rpm while in gear engine does not rev when pushing on pedal out of gear nor does the rpm change when in gear. few seconds later...
Is this a diesel?If it is check the fuel filter.If it is a gas burner,check the air flow(air filter,and filter box)for a plastic bag or paper sack sucked up in the intake duct.If this checks out fine ,have the cat.checked to see if it is stopped up.
Aug 29, 2009 | 2004 Ford F150
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
Husqvarna Partner Gas Powered Cut Off Saw K960 16" Logo
969 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
sgtstrat
Level 1 Expert
ken skalski
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
