Question about Microwave Ovens
I can't open the door. I press the button but nothing happens. What can I do? Is there a spare available?
  • 155 Answers
The door latch seems to be faulty or broken yes you can get spare parts just supply model number and your local supplier will get it for you be aware when dealing with microwaves there are very high voltages involved be very careful hope this helps you let me know how you went
Posted on Oct 06, 2010
Wolf Microwave model MW24. How do I repair door problems?
Microwave doors are very important have contact switches that switch off if open or damaged. Interfearing with the door could lead to serious injury. The best way to sort doors tha wont open or close is to replace with old doors of the same make that does not have the same problem.
Aug 03, 2015 | Microwave Ovens
When I press the button to open myMicrowave it starts to run. It did this for I week. Today I did the same thing push the bottom to open the door it open but nothing happen meaning no light on or nothing....
There are several switches (usually 3) located and attached to the door latch area of the microwave. One is a safety interlock that keeps the Micro from running with the door open. At first one of the switches were sticking slightly giving you the attempted run. Then enough stuck to cause the safety to sense it. The safety usually will blow the internal fuse or house breaker. If you are going to get it fixed, best to replace all the door switches and then the fuse also. If by chance it still blows the fuse again you have other problems. At this point I think its just the door switches and fuse.
Mar 24, 2015 | Tappan Microwave Ovens
Why will door not open
This happens when the latch hook loosens up and moves so that the door will not open when you press the button.
It's a very easy fix, but should be done by a repair person so that the door can be adjusted propery and no microwaves escape.
Hank
Jul 22, 2014 | Sharp Microwave Ovens
I have a F6 error on my Kitchenaid microwave, model number KHMS155LSS. I unplugged it for 5 minutes. Nothing changed. I closed the circuit breaker for 5 minutes. Nothing changed. If I plug it in, it...
F6 on these models means that the cook relay on the control circuit board is shorted, and it is cooking anytime the door is closed.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can buy a new circuit board (part number 8169733 for $150.27) from the Pros
here.
They're our favorite supplier.
Sep 07, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Door open button is broken, door will not open
door button mechanism is all behind the control panel.
there should be a couple screws holding the control panel on, you can see them when you open the door i believe.
you probably need to slide it one way or another to get it to unhook from its hidden catches..
there is the outer button you press with your hand thats available in 3 colors depending on your model #, and then the inner latch..
it will need to be checked to verify which parts are broken..
hope this helps,
best of luck,
ttfn
Oct 18, 2009 | Whirlpool MT4155SP Microwave Oven
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Door was closed after the latch was broken. Now I cannot open the door. Help
What usually breaks is the door open lever.
Or the rear of the door open button and the face of the lever may be worn.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Then you can contact Bosch at the number or site listed in the owner's manual to ask them about ordering spare parts.
If you don't have your manual, I would contact the manager at the dealer where you purchased it to ask them for Bosch contact information.
Dec 08, 2008 | Bosch Microwave Ovens
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
