Question about Rohl Perrin & Rowe Exposed Tub or Shower Faucet with Cross Handles....
How do I tighten a loose perrin & rowe kitchen faucet?
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
New Perrin and Rowe hand sprayer leaks on assembly
Hello, It is a defect in the product, you must replace the and sprayer.
Sep 15, 2013 | Rohl U.4759APC-2 Perrin and Rowe Bar...
My plumbing supply house was suppossed to order my Rohl shower set up with cross handles (RA4914 & 4912). Instead he ordered the lever handles. My sink faucet (RA1408) was ordered correctly with the...
Nice.
Paying that price for your shower faucet, I would think the supply house would work with you on that. eBay shows cross handles so they are available.
The plumbing supply store should be able to order what you want.
Sep 12, 2017 | Rohl Perrin & Rowe Exposed Tub or Shower...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Perrin & Rowe Mayfair kitchen sink faucet sticks
I wwould suggest contacting the source importer for this one, Rohl, at 1-800-777-9762. Be prepare with as much ownership information as you can. As a high quality high end faucet, all parts will most likely have to be special ordered so you want to know that what you are ordering is what you really need.
Mar 30, 2010 | Home
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
I have a Grohe Europlus Kitchen faucet. The base
there is a couple of plates with a little screw in the center that tightens up the plate got to tighten it up
Jun 23, 2009 | Plumbing
Rohl Perrin & Rowe Exposed Tub or Shower Faucet with Cross Handles.... Logo
129 people viewed this question
Top Rohl Plumbing Experts
obsteiner
john h
ray gallant
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
