Question about Compaq Computers & Internet
I have an old Compaq Armada 1750 laptop and some of the keys are not working.\r\n\r\nI have not used it for about 4 years but it was fine before then. Keys not working: F, I, O, P, 1, 2, 3 Any ideas?
    Master:
  • 362 Answers
I used to be a field engineer for Compaq and had one of these laptops with this problem. Some of my colleagues were able to fix the problem by hinging up the keyboard and spraying it with an air-duster canister. I, however, had no such luck and had to order a replacement keyboard. By the way, if you do try and clean the keyboard, ensure you have turned the laptop off, disconnected the power AND removed the battery too!
Take a look at this link http://wireball.com/hardware/laptops-mobile/armada_1750_repair
and you'll see a section on how to remove the keyboard, but only attempt it if you're mechanically-minded AND carefull. Regards, Nicam
Posted on Oct 06, 2010
Compaq armada 1750 manual
Hi, u can get access to user guide from: http://www.manualowl.com/m/Compaq/Armada-1750/Manual/106560
Mar 19, 2013 | Compaq Computers & Internet
Compaq Armada 1750 screen brightness has been adjusted to the point that I can not see the screen at all. I've tried all sorts of FN and function key combos....Any suggestions?
probably the inverter has gone inside the screen and will need replacing it is located in between the two hinges beneath the plastic trim
Mar 11, 2011 | Compaq Armada 1750 Notebook
Windows xp was installed on a compac armada 1750 was worling fine but after an hr or so it shut off and now wont boot or run windows all i get is black screen with window xp and 30 sec coutdown and......
On *********** board, there will be a battery, take that out and put it back in. if you have the OS disk. put it in. shut off computer, turn it back on press enter to boot from disk. either re format your hdd by deleting the partioned space or repair.
Apr 11, 2010 | Compaq Armada 1750 Notebook
How do you access the boot list on my compaq armada 1750
Tap the F8 Key as soon as the Laptop is powered on, keep tapping it till it brings you to Boot Choice Menu Options.. Options such as: Safe Mode, Safe Mode w/ Networking, Last Known Good Config..etc... are listed here..
Press and hold the F12 Key If You Need To Get To Boot Choices.. Such As Boot From CDrom, Boot From LAN, Boot From USB Device..
Nov 17, 2009 | Compaq Armada 1750 Notebook
Notebook cant see my 30 giga hdd
i assume the armada is a compaq product? if so, you may want to read your installation documentation- hdd may have jumpers, or spacers that need to be re-located! if it's not a compaq 'compliant' product, then good luck! compaq hardware is very 'proprietary'! meaning, if our laptop don't like it, then it don't work!! i've tried compaq ram on a toshiba- slotted right in! no prob. 'til i booted! didn't like it! seems very unfriendly to me! if your hdd 'kit' is supposedly compatible with your laptop, then, as i stated- check dox for jumper, or spacer settings. remove hdd and check for bent pins!! if there are any, very, very carefully- using fine tweezers- straighten them until they socket properly!
break one of and you're s.o.l.!
you may have a friend with the proper tools, and a steady hand who could assist, it there's a bent pin!
the hdd can appear to seat properly, but still have a bent pin. check any jumper/spacer settings first! also compatibility with your armada!
good luck!
Oct 19, 2009 | Compaq 30GB NOTEBOOK HARD DRIVE KIT FOR...
Accessing bios
Some Compaq's actually have a partition on the hard drive for the BIOS. If someone
> used FDISK to remove the partition, then you won't be able to get into the BIOS
>without either re-creating the partition or by booting from a floppy with the setup
>utility on it. One of Compaq's disks will re-create the partition, but of course,
>will blow away all the data on your hard drive.
>I had to download two programs from Compaq:
>1) PC Diagnotics
>2) Setup for Portables
>I got them from the Drivers section of Compaq's site.
>This was one of the files, it is for an Armada 1750, so it probably won't work if
>you have a different machine, but will give you an idea of what to look for:
> www.compaq.com/support/files/armada/us/download/8093.html
Nov 10, 2008 | Compaq Armada 1750 Notebook
Startup Problem
On the 1750 the setup bios settings are held on the hard drive, if you cant get any further I would suggest the drive is dead.
Jan 26, 2008 | Compaq Armada 1750 Notebook
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
