Question about Panasonic SC-PM533 Shelf System
I was given this mini system and when I put in a CD, you here it spinning, but the display will read no disc. What is the cause?
  • 677 Answers
Hi, i think the lens of the CD player is weak and will either needs tobe cleaned or to be replaced.
You can use a lens cleaner to clean the lens to see if it will play, after cleaning if it does not play that means the lens is damaged and will need to be replaced.
Take care.
Posted on Oct 06, 2010
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Player will not read cd . Cd will not spin
Without me seeing it, it usually cannot read the disc and is caused by a defective, or needs to be adjusted or cleaned, laser assembly as long as it is every cd put in it. It can also be the disc spinner motor. Either one of those is the most likely cause. :)
May 19, 2010 | Yamaha CDC-845 5-Disc CD Changer
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Players & Recorders
Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Jun 19, 2008 | Bose & Wave& Music System
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Sony mini hi fi shelf system reads no disk
you may have a defective lense . but check your disc to see if they are dirty..
Jan 06, 2008 | RCA RS2505 CD Shelf System
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
Cd player
RCA has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. Unfortunatly that unit is a throw away and no parts or service literature is available from RCA/Thomson. So if cleaning it does not do it, you are probably out of luck. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 16, 2005 | RCA RS2505 CD Shelf System
No Disc
If you sure that the system supports the disc's format.. and it wont play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 15, 2005 | Panasonic SC-AK300 CD Shelf System
Panasonic SC-PM533 Shelf System Logo
98 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
