Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W23 Hi, Lamp in front comes on, unit makes squeaking noise like a mouse a couple of times but screen never comes on. Unit just hangs after a couple of mice sounds.
  • RCA Master
  • 8,617 Answers
Sounds like the flyback is bad you can get a new flyback number 259296 at the following link and they provide free tech support so you can install it yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 29, 2008
Should I return my HP 500-214 Pavilion Desktop that is squeaking when the graphics change or I am downloading?
Windows 8.1 OS is the biggest piece of garbage to come down the pike since Ford came out with Edsel. Do yourself a big favor and take it back - see if you can get another unit with Win 7 installed. Some manufacturers give you the option of going back to 7 if the unit comes with Win 8. Check that option out also.
Apr 27, 2014 | HP Pavilion Computers & Internet
TRYING TO FIND SONY D52W23 HDTV AND ALWAYS GET RCA. LOOKING FOR MANUAL
sonny or JVC do not make the D52W23 thats strictlly an RCA model number
Oct 19, 2011 | RCA D52W23 52" HDTV CRT TV
Rca d52w23 tv power light comes on then off after about 3 sec. this happens 3 times without pic or sound, then tv stays off
vvghostvv,
You could literally have anything wrong with your unit. RCA standard procedure is to try to start 3 times when there is a fault then lock the unit out. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process as well as tell you where to get any parts you may need.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 08, 2011 | RCA D52W23 52" HDTV CRT TV
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
HI I have a RCA d52w23 and the screen has gone out, could it be the bulb?
you should have a light on the front that will blink if the bulb is bad, or the power supply could be bad
Aug 11, 2010 | RCA D52W23 52" HDTV CRT TV
I have the D52W23 RCA TV and it will turn on but no picture will come on the screen. when you turn it on it makes a churping noise every 2-5 seconds do you have any idea of what this could be?
You have may be two bad eletrolytic caps and a high voltage safety cap that are bad. And maybe a bad flyback. This is the common problem for this TV. Sorry!!!
Mar 01, 2010 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca 50 dlp hdtv and i replace the blub but the ligh isn't coming on does this tv has fuse
I assume you replaced the lamp since it had gone out. If the previous lamp looked ok, I would hang on to it as it may be ok. If it blown, then it can be recycled. You likely have a defective ballast board which supplies voltage to ignite the lamp. This may have failed on its own or could have been damaged if the original lamp blew out. There are other possibilities also, but that is the most likely. You also would want to try re-seating the lamp and be certain the lamp door is fully closed.
Nov 20, 2009 | RCA D52W23 52" HDTV CRT TV
Need a part # for a lamp assembly unit for my rca model # D52W23
This is a CRT TV and does not have a lamp assembly - it is driven by three CRT's.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
Squeak - Squeak
if it is kitchenaid/whirlpool unit it has 2 nylon ropes that connect door hinges to the springs on either side of door hinges.these ropes slide over plastic wheels and with time it stars making noise.just cln those wheels and apply little bit of regular bearing grease on those plastic wheel.noise wil go away.to do this u have to pull the unit half way out to access those wheels on lhs and rhs lower front end corners of the unit.good luck.
Aug 15, 2009 | Dishwashers
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
