Question about JVC AV-36D800 36" TV
I have full sound but no picture. the screen is completey dead
JVC av32750 tv works for a while and then picture goes out but sound remains on
Posted on Oct 17, 2010
My digihone smart TV screen had lines down it and now picture has completey gone
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 29, 2016 | Televison & Video
Should I change the T-Con Board?
t-con is my first choice, but failing that, the screen is dead, and the tv needs replacing.
Dec 11, 2015 | Vizio Vf550m 55-inch Full Hd 1080p 120 Hz...
SAMSUNG TV LA32D403E2 sound ok, does not show any thing on display
I have a LCD 32 inches LA32D403E2, the sounds are clear but the display picture is completey not there.
Please let me know if it can be resolved. The warranty expired 1 year ago.
Apr 07, 2013 | Samsung LA32D403 32" HD LCD MULTISYSTEM TV...
Our Lg Plasma 50PC1DRA popped then a very dim picture
If you have the same problem with another input such as a DVD player, this TV might need attention by a qualified service technician.
Aug 05, 2012 | LG 50PC1DRA 50 in. Plasma Television
We were watching tv and the screen went black, the sound got quieter and then it turned off. We left it overnight and now it won't even turn on. The red light isn't on to indicate the tv is off. We...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem...
Jun 26, 2011 | ViewSonic N3252w 32 in. LCD Television
Took car in 4 times. car completey dead. use truck to jump off. only have on battery for about 2 sec. dealer replaced battery. took it back again same problem. they replaced the postive cable. They had to...
My 08 GMC Yukon XL died 3 weeks after I drove it off the lot brand new! They said they replaced the computer but in the last two years its been in the shop 8 times for the same symptoms yours has... Tried to go the lemon law route and they gave me 5k towards another car but I had to pay the lawyer half of that. The problem now is that the service records show how many times its been in the shop so I cant sell or trade it without getting screwed!!!
Dec 18, 2010 | 2008 GMC Yukon
Olympus FE-190
on the right side of the camera where the memory card goes in thats where it is usally loose it it does that. try not to touch the part that slides out when you take the pictures or turn it on and it will be back to normal.
Jul 08, 2008 | Olympus FE-190 Digital Camera
Thin line across screen
Sounds like cold solder joints in the vertical circuit and also check around the yoke plug.
Apr 04, 2008 | Televison & Video
Dropped razor in toilet
Sounds like it is done for, yes. I know a way to save electronics if they are dumped in water, but it requires to fill it with water replacing fluids. Putting it in pure alcohol right away (remove battery first) might save it, as ir should replace the water and then evaporate completey when you take it out. Some contacts have probably corroded in your phone, so unless you are (or know) a repairman of electronics you'll probably need a new phone. :-/
May 16, 2007 | Motorola Mobility V600
Picture goes dead after 5-10 minutes
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Mar 03, 2007 | RCA 27F530T 27" TV
JVC AV-36D800 36" TV Logo
66 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
