Question about Craftsman Air Tools & Compressors
I have a craftsman 33gal air compressor model # 152938. i have a constant hiss (leak) coming from upper tube immediately behind the electrical box. upon some disassembly i found it's coming from the little spring/needle valve(?) that connects to the end of the tube. when i lightly pull the needle out the leak stops. i see the needle pushes against a spring plate that connects to the off/auto lever. is this needle valve not seating properly? the leak drops my tank pressure quickly enough to engage the motor every 5 minutes or so.
  • 3 more comments
  • fndrbss Oct 07, 2010
    I WD-40'd the valve and it seems to free and functioning okay. What I've noticed is, when the compr motor is running the little spring plate(connected to the auto/off lever) is in the down position (away from the needle) and when the motor stops the plate springs up. This pushes against the needle thus causing air to escape. I lightly pushed the plate down with a screwdriver so it didn't make contact with the needle and the leak stopped. First of all, what's the purpose of that needle? Second, is the spring plate supposed to make contact with the needle? If I had a parts schematic I could at least give the correct names of these things but I think you know where I'm coming from. Help! I'll give you 4 thumbs and toes up if you can fix/explain this.
  • fndrbss Oct 08, 2010
    919.152930
    Dumb question...is the rubber seal inside the valve? Any info on getting a new one?
    Finally found a blow up pic of parts. It's called a pressure switch (searspartsdirect.com says it's no longer available and no suitable sub). I think I'm screwed...may have to try some local sears repair shop to find one.
    I tried WD (it's called a pressure switch by the way) and still no luck. Someone else suggested a bad rubber seal in the valve. Naturally the part is no longer available...I'm probably screwed }:-(
    Found out the part in question is called an unloader valve. Located one at mastertoolrepair.com for $20! Hope it works. Thanx for the help.
  • 760 Answers
Actually this valves opens when the compressor shuts off.The pressure switch (which is activated by the larger air line attached to the tank)has a lever that opens this small valve to bleed the air from the compressor so that when it restarts it doesn't start against the tank pressure. The switch is probably working as intended, as it is venting as it should. Most likely the check valve at the tank is not sealing, allowing the air to escape from the tank through the valve attached to the pressure switch.
Posted on Oct 09, 2010
  • Tom W Oct 10, 2010
    Note in my previous answer, I told you it was the pressure switch. Most like it is not bad. It is supposed to let air bleed out until line is empty. If you did need a new one square d makes pressure switches that would work. You can get one at an electrical supply or Graingers. The check valve I was referring to should be mounted either right into the tank, or the fitting closest to the tank. This keeps the air from leaking out of the tank back to the compressor. The vent valve on the pressure switch opens the vent when the compressor turns off. If the check valve leaks, then it will allow air to continue to escape. Some are "pilot" operated some are not. A good cleaning of this might work, but some have rubber seats that get worn.
    OH, now that you sent your exact model number I see the pr oblem. This a smaller compressor that has a minifold assembly the incorporates the check valve into it. You might try taking it apart and cleaning it. If there are any rubber parts inspect carefully. I did notice that they say these parts are not available either. The item you need is the check valve or restrictor. Part number CAC-1391 Try cleaning it. You might try this web site too: http://www.mastertoolrepair.com/mobile/s...
  • Craftsman Master
  • 8,404 Answers
Remove the small tube and clean both the ends and shoot some cleaner (WD-40 or similar) down the tube. Reassemble. Make sure it it tight but don't strip or break it. There is a special tubing wrench available to properly tighten these brass connections. If you are careful, you can get by without using that special wrench.
What is happening: This tube you are working with supplies real time pressure to the control switch. When the pressure is down, the spring relaxes and allows the contacts to close energizing the motor. When the pressure reaches a predetermined setting, the spring compresses and opens the contacts turning off the motor. Any leak in your system will of course allow the bleeding off of pressure and will thus turn on the motor.
I hope this helps you with your leak. Thanks for using FixYa.com
Posted on Oct 08, 2010
  • A Miller Dec 07, 2010
    You could replace the control switch ... one of the shelf at the ACE or other fine hardware retailer shold work ... You will of course have to set the switch for the proper pressures. The instructions should come with the switch.
  • 15,935 Answers
There is a rubber seal at the base of that valve that is likely worn.
Disperse pressure before working on it.
What is the model #?
Should be something like xxx . xxxxx
Thanks!!
  • 10,865 Answers
Hi Michael. Thanks for choosing fixya! That needle valve may just need a little lubrication. Get a can of WD-40 and squiirt a little on the valve. Move the needle up and down as you squirt it. Repeat as needed. IF this does not do it, you will have to replace the valve. It is available at searspartsdirect.com
Please give my answer 4 thumbs up. Thanks. Joe
Posted on Oct 06, 2010
  • Joe Hogan Oct 08, 2010
    Hello again. go to searspartsdirect.com, enter your model number and you will see an excellent set of schematics for your compressor. order a new part and install it. Joe
    Hello again. I just got the updates on your repair discussion. As you now know, Sears and Craftsman only maintain a parts inventory for ten years. After that, finding parts becomes doing just what you said, a "hunt". Actually the part is common, it is just finding one that will fit your app. That said, I would consider checking on Craigslist.com. Often they have used tools and you may just find a duplicate for little money which you could use as a parts source. Joe
I have old Ingersoll Rand compressor type 30 model 15T serial # 243496 Blow fuss when restart ?
Probably a faulty non return check valve, when the unit reaches pressure air in the delivery pipe is vented down at the pressure switch. If the check valve is passing back this will cause the unit to try to start against a pressure causing it to pull high amps and trip. If there is a constant hiss coming from the pressure switch when the unit stops it will be the non return valve. There should be a short hiss of air when units stops If there is no hiss at all when the unit stops it could be a faulty pressure switch. If it is a quick fix would be to create a small leak on the delivery pipe to vent the line down.
May 28, 2014 | Ingersoll Rand - Rand Type - 30...
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
Husky model WL6605-00AJ,will pump up to 65psi,thats all the air showing on thr gauge.The compressor is still running
You Might Have Water Condensation Inside The Tank Therefore It Can Only Fit So Much Air Into The Tank Which Is Why Its Always Better To Completely Drain All The Air Out Of The Tank When Not In Use.
Mar 17, 2012 | Air Tools & Compressors
When it runs it sounds like an air leak from the engine and the tank does not fill. i do not hear air leaking when not running.
This sounds like the compression release valve is leaking. This valve bleeds the cylinder pressure to allow the motor to start without having the load on it. On this size compressor the valve is often built into the pressure switch. It is a little "pintle" type valve and you will hear hissing while unit is running but the opressure will not build up very much. When the pressure switch calls for the unit to run, the little valve closes with the switch. COntamination or other stiction keeping the valve form closing will cause the problem. You will find this near a tube that goes to the pressure switch. The switch itself hooks into the tank, but this little tube will connect to the cylinder head or the main tube from the compressor. Yours may look similar to ones at this site:
http://www.generalairproducts.com/Fire-Protection-Products/accessories-pressure-switch-a-switches-check-drain-a-pressure-relief-valves.html
The valve is also commonly called the "unloader" valve.
Jul 29, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Unable to locate what I think is the pressure relief valve located under the on/off box. looks like a small needle valve but leaks air constantly. any ideas?
If it leaks constantly until the tank is empty or very low, the problem is most likely a leaking check valve. The pressure relief valves mission is to empty the pressure line between the chech valve and the sylingers to facilitate unloaded restart of the motor. The check valve is usually mounted directly on the tank an connected to the large copper tube from the sylinders as well as the relief valve through a smaller and thinner tube (often nylon). Empty the tank, unplug the power and open the unscrew the cap of the check valve and retreive the spring and the valve disk and inspect for damages, foreign objects or replace if needed. Refit it and test run the compressor. If your problem is that the relief valve leaks only while compressor is running and just after it stops, the problem is likely to be the relief valve itself. This is usually an integrated and rather delicate part of the pressostat (pressure, on off switch box) and you may need to replace it as a unit unless you can clean it by pressurized air or gently dismantle it for inspection and cleaning or removing foreign objects or dirt.
Feb 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a Sears 33gal vertical compressor. About 8 years old. I keep tripping circuit breakers whenever the compressor is activated and starts to pump. Please advise
either the motor is bad or the pressure relief valve is inoperative forcing the compressor motor to try to start with pressure already in the pump
Oct 15, 2010 | Craftsman Air Tools & Compressors
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Leaks air at the pressure switch
start your compressor and let it buid up pressure to turn off. then unplug from power.lossen the fill tube that goes from the pump to the tank. when you loosen it. if it leaks air then your check valve is bad and will have to be replaced.
Dec 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor motor/capactitor problem?
It sounds like either the check valve or the switch that lets the air pressure off of the pressure switch is broke. After the compressor pumps to shut off pressure, when it shuts off, it should let a short burst of air from the switch. If it does this, that parts good. Give it a little time, then manually push that plunger on the switch.( you're trying to see if the check valve, which is a one way valve, is leaking air back into the cylinder) If air is release from that plunger, the check valve is leaking and will not let the compressor start, because air has leaked back into the cylinder.
Oct 27, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
133 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
