Question about Kenmore Washing Machines
Kenmore series 80 wash machine does not engage into spin cycle full or emlty
  • 5,911 Answers
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Oct 07, 2010
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 80 Series Won't advance to spin
You will need to replace the timer. Let me explain why;
After the agitation cycle, the machine will enter a drain mode where the basket will not spin, only drain. After some time, the timer should 'pause' causing the machine to engage the spin clutch. The timer contact has become stuck, not allowing the pause, thus never entering engaging the spin clutch.
Jul 02, 2008 | Washing Machines
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
91 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
