Question about Laing Thermotech Housing, Pump Sm909nt - 26 3/4
I have a sm-909-nhw-18 3/4"in my jacuzzi hot tub. It vibrates and then shuts down when the temp. gets about 90 degrees and I get a flow error message. This is my third pump in 6 years and I am out of warr. Is there a repair kit I can get.
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Sep 15, 2013 | Jacuzzi Pool & Spa
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Overheating problem
It sounds like the problem is in the main control box. Since the tub shuts down after reaching 110 degrees, the high temp sensor is doing its job. This sounds like a job for a qualified professional. Do get a price for the service call as they are usually expensive. Circuit boards start at 200.00 and go up.
Sep 15, 2009 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Jacuzzi not getting hot enough
The cover needs to be closed completely to keep the heat in the cabinet. No problem.
Dec 29, 2008 | Jacuzzi Home
Laing Thermotech Housing, Pump Sm909nt - 26 3/4 Logo
548 people viewed this question
Top Laing Thermotech Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laing Thermotech Garden Expert? Answer questions, earn points and help others
