Question about Maytag MZD2766G Side by Side Refrigerator
Refridg door is dragging along bottom of fridge when opened. how do i adjust this door so it does not drag?
    Sergeant:
    Champion:
  • 351 Answers
THAY HAVE A PLATIC CAM ON HING AT BOTTOM OF DOOR IT HAS GONE BAD OR NEEDS TO BE REPLACED
Posted on Oct 08, 2010
How can I set the drag on a shimano R 2000 spinning reel
The letter "R" on a Shimano reel typically indicates it has a rear drag.
you should find a know on the bottom end of your reel that allows you to adjust drag tension. Just Remember to back off or loosen your drag when not using your reel to keep your drag in proper working condition.
Dec 06, 2014 | Fishing
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
Refrigerator door drags and does not shut properly.
adjust hinge remove hinge cap loosen screws lift up door and retighten screws cheers
Dec 12, 2013 | Maytag MBF2556HEW / MBF2556HEB /...
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
We left fridge door open for about an hour while we cleaned it and now it is not cooling?
you may of gone into a defrost timing this along with door open will take some time for refridge to lower temp of the walls and door then work in a normal fashion. do youhear the compressor running? you could not have damaged the ref. by just leaving the door open. the most that could take place is over working the compressor. then it would cut off under heat overload. wait some time and let the unit cool off . i would remove food and operate under no load until things stabelize
Feb 01, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Freezer Thaw
Loosens screws on the top hinge and pry the handle side of the door up then re tighten the hinge, bottom of the door is probably dragging
Jan 24, 2009 | GE Refrigerators
Maytag MZD2766G Side by Side Refrigerator Logo
79 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
