Question about HP Wireless Optical Mouse
My HP optical wireless mouse has just recently decided to flip the primary mouse buttons, where as the RMB now acts as the main button. I am used to the standard LMB configuration, and no matter how many times I try to configure it on the control panel for the mouse, it reverts back to this annoying stage. Can anyone provide me with a fix for this?
  • Nalin DSouza
    Nalin DSouza Oct 06, 2010
    which Operating system are you using ???
  • lehighvalley Oct 06, 2010
    Windows XP media center edition. Sorry, my bad.
    Guru:
  • 224 Answers
Ok well open up control panel and double click on mouse,once that is done u'll get a new window asking you to change the selection of when you click what happens change the selection click on apply and then ok and let me know what happens,if this works out would like you to help me get a 4 thumbs up if not let me know and i'll give you another solution
Posted on Oct 15, 2010
I bought a cordless mouse Fha 3410. When I let down the left click, it acts like double click, so do not let me select objects. I need to solve this problem, since I can not work normally in any...
Hi..
Go to - Devices and Printers in Control Panel
Go to - Mouse properties and check for the Doubel click speed.. See to that it is not set to the max.
May 30, 2011 | HP Wireless Optical Mouse
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
Mar 12, 2017 | HP Wireless Optical Mouse
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
Changing the batteries in a hp optical wireless mouse
From pictures, it looks like the top part of that mouse slide down.
Try holding it with the buttons facing toward you, and pushing with your thumbs on the top silver piece of the mouse away from you.
May 18, 2009 | HP Wireless Optical Mouse
Want a left handed mouse
To change mouse settings in XP for left-handed users:
Click Start and click Control Panel.
Double click the Mouse applet.
Verify that the Buttons tab is selected.
Select the Switch primary and secondary buttons option is selected.
Click OK.
May 07, 2009 | HP Wireless Optical Mouse
HP wireless optical mobile mouse
Try changing the batteries or charging if it is rechargeable or try re-syncing using the syn button.
Nov 26, 2008 | HP Wireless Optical Mouse
Microsoft wireless notebook optical mouse 1024`
I have a Microsoft wireless optical mouse 3000. There is a silver button on the end of the mouse that usually faces you when using the mouse. Press that silver button- while holding the button in, use your fingernail or something to help with gently lifting the main panel on the top part of the mouse. Lift up on the end of the panel that is closest to the silver button. The panel comes entirely off, revealing the inset battery. It took me a while to figure it out since I installed the first battery.. it has lasted over a year. Hope this helps with yours. Have a blessed day!
Jul 12, 2008 | Microsoft Wireless Notebook Optical Mouse...
Mouse Issues
There is a light/button on the USB plug. After inserting the USB key press that button then immediately press the connect button on the bottom of your mouse.
Hope this helps fix your problem.
Mar 14, 2008 | HP Wireless Optical Mouse
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 04, 2007 | HP Wireless Optical Mouse
you have two micro switches that wear-out quickly. try going to. Control panel. Click on Devices. Then on Mouse try switching your right button to left button on button options. try hitting restore defaults. Make sur your remote sending unit is plugged in and the lie is on steady. good luck Joe_Rex
Apr 26, 2007 | Microsoft Wireless Optical Mouse
HP Wireless Optical Mouse Logo
1,608 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
