Question about Toro Garden
It starts and runs for 5 seconds and then stops...fuel problem?
  • 755 Answers
I would drain the tank and carb completely and allow to air dry for a day. Then get some fresh gas *(clean out the gas can too) and try it again. If the problem persists the carb probably has fuel flow issues. A stuck fuel float or obstructed needle/seat.
Posted on Oct 07, 2010
Fuel being being pumped out off r/h air filter for a few seconds, does it when trying to start as well!
it's normal for it to run for 5-10 seconds if you turn the key but do not start the car it will shut off.
Apr 15, 2013 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
I have a 97 jeep grand Cherokee, when it has sat for over an hour it takes 8-10 seconds of the starter running before it starts. If turned off after running, and started within a few minutes no problem,...
Fuel pump. The valve in the pump that stops the fuel from draining back into the tank is not working so you crank and crank until the fuel gets up front. Turn the key on but not to start for 5 seconds then off do it five times and then try to start it should start right up
Nov 27, 2011 | 1997 Jeep Grand Cherokee
Fuel pump works but no fuel in the fuel rail
can you hear the fuel pump run for 5 seconds when you turn the key to "ON"? Then it stops running until you turn the key to start. Do you have 40 PSI at the fuel rail?
Have you changed the fuel filter?
Dec 03, 2010 | 1998 Ford Windstar
2006 Cherokee KJ 2.8 CRD intermittent problem. Engine starts then stops. After priming at fuel filter will start & run ok
fuel pump relay . you should hear the fuel pump run for 5 seconds as soon as you turn the key on .after that the cranking sensor takes over when engine it turned over to start
May 26, 2010 | 2006 Jeep Liberty
Starts very easily runs for 5 seconds then dies, pump quick start bulb once, starts in 1 pull run for 5 seconds , new clean fuel, carb still has factory stops on adjusters limiting change to about 1/4...
hi , if you have a compression tester use that to test for worn piston rings /scored cylinder , if not remove the exhaust and visualise the cylinder and check for scoring , remove the spark plug and block the hole with your thumb , it should feel nice and night when you pull the saw over , if it fails then you will need replacement rings and/or piston and cylinder .
hope this helps
May 20, 2010 | Garden
Cold days car will start and run for 3 seconds and stall for 20-30 min until it starts and continues to run
The reason is that , the fuel line is out of fuel, so the running for 3 seconds is just the use of the trapped fuel in the injector line, after which it will stop. The solution is to on the ignition by turning the key without starting the ignition. this allows the fuel pump to release enough fuel into the fuel line and the injection system. Allow this for 5- 7 seconds, then start the car. It will run without interruption.
Dec 11, 2009 | 1995 Volvo 850
Aprilia mx50 will kick over then stop after 5 seconds kick over again and will stop after 2 seconds, then wont start, leave for a few mins and will kick over and will run for 5 seconds and so on, any idea...
If your bike starts even for 5 seconds you should investigate your fuel delivery system.Check fuel pump,filter,try spray carb cleaners like Gum Out.Most importantly make sure your choke is working.You got your ignition (spark) it is most likely fuel related.Good Luck.
Sep 19, 2009 | 2005 Aprilia MX 125
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
99 gmc wont start
check electric fuel pump operation ( located in the fuel tank ). Occasionally a fuel pump will burn out when running out of fuel, due to the fact the pump runs DRY for about 30 seconds till the fuel stops flowing out of the injectors, the engine quits, simultainously losing oil pressure which FINALLY shuts off the fuel pump. Sometimes TOO LATE. Hope this helps
May 01, 2009 | 1999 GMC Suburban
My 1990 F150 will not start sometimes. If I turn the switch to the on position and the fuel pump continues to run after 5 Sec , It will not start. If the pump stop running after 5 Sec , it will start.
when u turn the key to run but don't start the fuel pump shuts off after 5 seconds + or - 2 seconds, this is normal, the common cause of no start on your truck is the TFI ignition module on the distributor, subject of many recalls for failing, also change the stator inside the distributor, use factory parts, aftermarket parts fail very quickly. here is a picture of the parts.
da17e03.jpgThis is the stator
This is the TFI ignition module.
Apr 02, 2009 | 1990 Ford F150
Garden Logo
126 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
