Question about Refrigerators
Refrig. will not stay coolTemp goes up to 60 then back to 34 for an hour or so then back up.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
What does lcd display show when shaver is fully charged from new
Not sure of the model you have but does the owner's manual give you any idea of how it should display? Most I've seen either display a full bar of small rectangles, show '100%' somewhere in the display, of briefly flash every few seconds.
If you've charged for 34 hours I'd suggest just using it for a while, then plug it back in and observe the display to see what indications have changed.
Mar 13, 2015 | Cell Phones
Food is starting to spoil more quickly than it should. The refrig temp on the door is set at 34 degrees which is the lowest it will go. The temp. on the refrig thermometer says it is 60 degrees. What...
You can get a small digital thermometer at your local hardware store for a pittance. ... For most refrigerators, this temperature coincides with the lowestsetting or one of the ... If your refrigerator is really full with items, lower the temperature a bit. ... they're not going to go bad because they were at 41degrees for a few hours.
Sep 12, 2013 | Samsung RF267AE (25.8 cu. ft.) Bottom...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Refrigerator running. freezer will not go below 40
you need to clean the bottom of frige of dust and water there ,, and if that dont work clean pipe that goes up the back of frige
Aug 10, 2009 | Refrigerators
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
WARM REFRIGERATOR
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
