Question about Samsung LTN1565 15 in. HD-Ready LCD Television
My monitor keeps blinking that green light but won't turn on. I've tried unplugging it and plugging it back in and pressing the power button. Nothing works, any help?
CAYPIANAN
  • 227 Answers
SOURCE: Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
Posted on May 12, 2009
bkamen
  • 18 Answers
SOURCE: Power button blinks - won't turn on
When the power light blinks, it indicates in PC mode that there's no PC signal (depending on the monitor, it could be the sync signals or a combination of sync and video.)
You SHOULD be able to hit the source button to see if the monitor then comes up to allow you to watch another source like the S-Video, Video or TV (ok, so good luck picking up any signals if you're in the US -- but you SHOULD see static and this is probably the best "quick test" for now).
If you see static... your monitor works for most part.
Where you would troubleshoot now is the cable for your PC and the connector to the monitor on both the PC and and the monitor end. These can come loose, get abused and cause solder breaks on the circuitboards within (less common but possible).
Most cable issues I see are just bad cables from extremely tight spaces bending the cable and causing wiring breaks in the connector housings. (unrepairable because of the molded cable end)
Try those out and let me know.
-Ben
Posted on Jul 07, 2009
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
dlundmark
  • 797 Answers
SOURCE: Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Posted on Oct 20, 2009
  • 117 Answers
SOURCE: blinking blue light with a clicking noise coming
the clicking is the relay sending power to unit/but if there is a fault it will power down/tv shop mate
Posted on Dec 23, 2009
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Jun 23, 2012 | Televison & Video
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Printer will not respond
Canon S330 Turn off printer
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Samsung LTN1565 15 in. HD-Ready LCD Television Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
