Question about Altec Lansing 121i Computer Speakers
My speakers only the bass when i hook them up i hear the bass but not the sound please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
It sounds like you have subwoofer system that requires satellite speakers for the high frequencies. If you have these satellite speakers, but are getting no sound, either you have connected them incorrectly, or there is a problem with the amplifier that drives the satellites.
Posted on Oct 07, 2010
Elite 6035 surround sound. How do I connect?
Need help hooking up my surround sound speakers with receiver ...
www.hometheaterforum.com/.../286294-need-help-hooking-up-my-surr...
Sep 1, 2009 - 4 posts - ‎1 author
Ok I have a brand new set of Genesis G-6.1 surround sound speakers (I got them for $20 brand new in the box so I ... Or do I just connect all the speakers to the receiver like usual? ... Elite Audio EA-608 ... Genesis G-6035 Olin Ross - Beginners, General Questions & HTiB (Home ...
Apr 7, 2009
Info. on Genesis 6.1 Home Theatre system - Beginners ...
1 post
Jul 24, 2008
Can't hear the bass sound... - Receivers/Separates/Amps
May 30, 2008
Davinci audio? - Speakers, Subwoofers & Headphones
Aug 28, 2006
More results from www.hometheaterforum.com
Have any universal codes for EA-6035 5.1 A/V Surround ...
Dec 25, 2015 | Elite Televison & Video
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
When I hook up my speakers the music sounds horrible its like the bass is not transfering over to the speakers how do I fix this problem
Lets check the simple stuff first. Check the speaker calbes and make sure that they are both hooked up the same way. If you have colored cables, then make sure that both "red" (for example) wires are connected to the positive(+) terminal of the speakers. If you have one to + and one to -, you will get sound out but lose the bass. This is because the speakers will be out of phase. This is the most common cause of the loss of bass response.
If that does not resolve the problem, please check with headphones to confirm that the problem is with the amp and not the speakers. Update this with your results.
Thanks,
Dan
Nov 15, 2010 | Denon AVR-3805 Receiver
Sound quality bad i can hear bass but really no treble or mids
Could be that those speaker components (mid-range spkr., tweeter) are blown. Try hooking up a similar type speaker and see what happens.
Apr 12, 2010 | Aiwa XR-M55 Shelf System
They also try to play the bass
a crossover cuts the certain tones out of the sound.example: the high side cuts out low and mid tones,or the mid side cuts out high and low. The only problems this could be is that the crossover is not set right or not wired right. These speakers should be plugged into the high side of the crossover. If wired right and set right then your crossover is no good.
Mar 23, 2010 | Kicker KS13 Car Tweeter
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Sound is coming out but no bass
Make sure that the rca cables that you have coming out of the deck to the amp arent switched to highpass(no bass) and check the amp and make sure that the crossover is set to lowpass(LP) see if that helps
May 30, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Altec Lansing 121i Computer Speakers Logo
616 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
