Question about HP PSC 2110 Color Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed alignment sheet facedown on scanner glass, as instructed. Scanner was not able to scan the aligment sheet. Printer failed to align cartridges. Everytime I turn printer on, it runs through alignment process again but never fully aligns. Scanner seems to be having problems. What to do?
  • chudecek84 Oct 06, 2010
    thank you djgillstudio, I will check the color cartridge and try again.
    Sergeant:
  • 174 Answers
Did you check the print.
Do you feel the print quality is very good in color and black.
Any portion of print is missing.
If yes then you change with original new and do the alignment.
Posted on Jul 23, 2012
    Scholar:
  • 107 Answers
Hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Posted on Oct 06, 2010
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp 2210 all in one printer/scanner
after replacing the ink cartridge align the printer. Press alignment cartridge located in the printer properties. After printing the alignment get the paper and put it in the scanner. The computer reads it
May 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp 2110 All in One Printer
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Jul 29, 2007 | HP PSC 2110 All-In-One InkJet Printer
Scanner bar jammed by cartridge allignment
Any fix for this I have the same issue?
Dec 11, 2006 | HP PSC 2110 Color Printer
HP PSC 2110 Color Printer Logo
343 people viewed this question
Seeker5211
Seeker5211
