My 64 caddy devill will not firer but it has new spark plugs and the engin anley has 5,000 on it
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
You need to put this question under automotive
Posted on Oct 06, 2010
I changed the sparkplug on my 2001 dodge caravan with a 3.3 liter engine and now it seem like its running on 5 cylinders it bucks . I checked the coil and it has sparks to every spark plug . What else can...
Wires could be bad.If use new one good ones only.Reduce the headage.Check and clean all connectors.Any codes?Go up the hill fast and keep eye on engine light.Coils???
Sep 22, 2017 | 2001 Dodge Caravan
How to remove spark plugs on '93 cadillac devil
THE FRONT ONES ARE EASY. THE ONES NEAR THE FIREWALL ARE THE TOUGH ONES USUALLY NOT A DO IT YOURSELF PROJECT, AS YOU NEED TO REMOVE THE TOP MOTOR MOUNT AND ROLL THE ENGINE FORWARD TO GAIN ACCESS.
Oct 02, 2012 | 2002 Cadillac Deville
My 1996 mercury 9.9 miss firers under load
The most common cause of any ignition misfire (which i think is what you have here) under a load is that the plug wires/and or plug wire boots are defective and shorting to the engine case or that you have a cracked spark plug insulator. If the plug wires are the cause you can spray water on them while the engine is running and the misfire should occur. This method is not fool proof but works well in may cases.
Please rate my help for Fixya, it all the reward I ask for for my time helping you.
Dec 29, 2011 | Seloc Mercury Outboard Engine Repair...
Hi my derbi senda xtream has fuel and compression but the spark is realy week and not consestent it firers every now and agen can u help
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Dec 10, 2011 | Derbi Senda R 125 4T Motorcycles
Have a c50, i turn key to on position and flip power switch on. fuel system begins to power up and then stops mid way through the cycle. starter will work but bike will not start.
U check the bike sparks plugs distributors caps and those sparks plugs itself for of the bike for dirtyness and dirts by tries cleanning it with some DW40 chemicals spray for better contact for fuel ignition burn?Yes,than check all of the sparks sets firering gaps in the bike are dull and colors of those sparks plugs are blues or old blues colors in the firering gaps.The sparks plugs set in ur bike are 3 or 4 years old?Yes?Change the bike for another set of spark plugs.
Oct 02, 2011 | 2005 Suzuki Boulevard C50
Wont start has firering spark
hi
You said spark plug is firing that is fine have you check fuel system check your fuel pressure regulator,also check your spark plugs conditions.
It can be fuel pump but first check the pressure fuel.
Feb 21, 2010 | 1996 Dodge Caravan
Polaris 90 will not start...turns over but not firer
coil maybe bad. lots of reasons here
cdi maybe bad i would try boot on spark plug wire first screws off and back on with new one
Dec 05, 2017 | Polaris ATV
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
