U1 is a filling fault , so you will have to check the water supply into the dish draw is turned fully open and the hose is not damaged or kinked . Ensure the spray arm inside the draw is free to rotate and clean out the strainers inside as well .It would also pay to check the levels on the machine .If you run the dishwasher whilst using water else where the water pressure may also be dropping to much or even changes in temperature may effect it .
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
try a Reset from the player's menu. You'll find that it rebuilds it's database and your tracks will show up.
- Press & hold the Menu button
- scroll down to Settings
- Select Default Set
- Yes
I hope it works for you as it i=did for me :-)
