Question about HP (ED808AA) 2 Speakers
My speakers are not working all i can hear is a constant buzzing noise
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How can I make buzzing noise stop?
quit using the bluetooth speakers . quick and easy
Jul 05, 2015 | Audio Players & Recorders
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Apr 25, 2015 | Polaroid FLM-3734B 37 in. LCD HDTV
Model # 200PB101FREV00
Katherine,
Many times when a desktop is making a strange buzzing noise - it is due to a fan malfunction of some sort. Other reasons include a power supply that is faulty or possibly a bad internal speaker.
I would first check the fan(s) for the computer. Start by turning the computer off all of the way. Next, unplug the cords from the unit. You'll need to isolate just the computer tower itself. Next, you'll want to get some compressed air or a vaccuum and gently clean out the areas where the system case fan vents are. If you know how to open the case for your desktop, it wouldn't be a bad idea to make a quick visual check inside of the case for things that may be caught in the fans. Some desktops open via screws on the back plane, and some open with a pull tab/lever.
If cleaning out the dust doesn't resolve the buzzing noise - then you'll need to make sure that the noise is not part of the electronics. If you are hearing an actual electrical buzz and not a speaker or fan noise, then there is likely a larger problem with the computer. In that case - I would take the computer to a certified professional for diagnosis.
Another culprit of buzzing noise may be a CD/DVD drive with a disk stuck in it. Make sure that you have ejected the drive to ensure no disk is stuck in the drive.
I hope this information helps!
Nov 22, 2011 | Compaq Computers & Internet
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
Constant buzzing noise after warming up
uninstall the sound driver and reload. if this didnt work, reload the windows.
Aug 14, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Buzzing noise
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Jun 19, 2007 | RCA RS2640 CD Shelf System
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
HP (ED808AA) 2 Speakers Logo
102 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
