Question about Altec Lansing Multimedia Computer Speakers
Need to know the voltage on the dc power adapter for ACS5 model
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Hard to find info. It looks like they run on about 14 to 15 volts dc. It's not critical. Check local electronic surplus stores or thrift stores before spending a lot more elsewhere.
Posted on Oct 07, 2010
  • Promethean Nov 14, 2010
    Found these speakers for sale online, with a photograph of the power brick. 15v DC 500mA
I need a replacement power supply for Sportcraft Arcade Hoops. Existing AC Adapter is model MW35-0750350
The adapter model number doesn't matter.
You need the output volts, AC or DC and the current (mA) off the existing adapter. You also need to match the input voltage for where you live, either about ~115v or about ~230V.
The last thing you need to match is the proper connector for the game and if DC the proper polarity.
If it's DC the easiest way is to go to a local store and get a universal adapter that can set multiple voltages, has multiple connectors and can possibly set both polarities. Just get one rated at equivalent or slightly more current than the old one. If you have to purchase one with significantly more current, you may need to set the voltage a little lower.
Nov 02, 2016 | Computers & Internet
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Power output
I don't know what you're asking about but if you need a power adapter you can find them cheaply online by searching google or yahoo etc. for the particular brand you need. There are tons of dealers out there with quality reconfigured, rebuilt and even new adaptors for very low prices. Good luck!
May 29, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Where can i find an ac/dc adapter for my philips portable dvd model no. PET714/94. i lost the adapter.. i want to know how much it will cause?
You are going to have to find out, the Ratings of that supply, you need to know what Voltage and current are supplied FROM it. Any AC/DC adapter, with the right, Current, Voltage and End Plug, will work. Often it can be found on the actual unit, itself. Or in the manual, under POWER: Now once you know this you can get a suitable one, the thing to watch though, is the Plug End, they are all different and critical. Now at places like Radio Shack, and the like, often you can buy after market adapters that are Voltage adjustable, PLUS they have a special "End" on them, that will mate with a number of differing "Ends" one of which, will no doubt fit the unit, as all regular ones are included and then some. Then there is eBay.
Mar 24, 2010 | Philips DCP855/37 Portable DVD Player
Laptop will not stay powered after replacing dc jack
Dear friend,
You must have some knowledge atleast about the various kinds of power supplys used in different electronic appliences. Otherwise you can't move further. The power supply generally goes to various ICcs and switching devices in the motherbord for differnt purposes. It varies from manufacturer to manufacturer; model to model and so on. What about your status in electronics? The output voltage of the adapters - and thus which in the motherboards- varies form company to company and model to model. You can veiw it on the adapter as ' OUTPUT:19V, 4.74A' and like this. It will be the reading that you must get with the adapter. If you don't get this voltage -without plugging it in the AC outlet- the adapter is faulty. If you don't get the voltage mentioned in the adapter on the motherboard- if the adapter is good- then it is somthing wrong on the motherboard.Reply if you need further assistance.
Mar 15, 2010 | Computers & Internet
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
793 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
