Question about HP Office Equipment & Supplies
Have replaced a tri-color cartridge in hp photosmart C4280 all-in-one. it took too long to align and then I pressed cancel, there was a little movement then indicated printing for a period now of more than 10mins. nothing is happening
Turn the machine off and start again as you would when you reboot your computer
Posted on May 29, 2008
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
Hp photosmart c4280 setup
Sounds like that printer/scanner has a problem right out of the box. I would consider talking that piece of hardware back for an exchange. It you have tried it on three computers then it is the printer/scanner and not you.
Feb 20, 2009 | HP LaserJet 3390 All-in-One Multifunction...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
gary.schaut@gmail.com
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280
hmmmm...assuming that the cartridge is installed properly, yes? seems that your black ink cartridge may need to go through a 'clean' process, prior to alignment(sure wish that the replacement folks would insist on cleaning out the old heads, before doing an alignment. It's like changing the oil on your car, but using the old filter. Same gunk still in the system.
Jan 29, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Ben Johnson
