Question about KitchenAid KERC607 Electric Kitchen Range
There is a white line between the glass panels on the oven door. Can I unscrew the inside door panel to fix? Charleen
  • 10,865 Answers
Hi Charleen. Yes. Just get a helper to remove the door from the oven. To do that open it up about 1/4 til it stays put and then pull up on both sides at the same time [thus the helper]. Once off rest it upon a large towel so as not to scratch anything and remove the screws. J.
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Posted on Oct 06, 2010
How do I remove the door from the range. I would like to clean the inside of the glass window
Typically, the doors are removed by lifting or moving the rounded guide that you can see when the door is opened. But as far as the inside of the glass, even with the door off of the oven, you would have to unscrew the inside door panel from the door and take it entirely apart. Unless for extreme reason (completely fogged with grease), I wouldn't recommend attempting.
Jun 04, 2017 | Kitchen Ranges
How do you clean the dirt/food "in between" the glass in the bottom oven door
Open the oven door. In the inside you will see a number of screws along the edge of the door. Unscrew them and you will find that you can lift/split the inner panel from the outer panel. If it sticks look for more screws at the side of the door to make sure that all the screws are removed. Lift the inner panel carefully an you will have access to the "inside" of the glass panel. Re assemble by reversing the procedure.
Mar 31, 2015 | Ovens
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Nov 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
KitchenAid KERC607 Electric Kitchen Range Logo
154 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
