I have a Panaonic PT-56LCX70K. TV would not come on. I replacd the DPL lamp now TV runs correctly but has very very low brghtness. Note: When TV is turned off the screen goes black bu DPL lamp is still lit for 2 mins, 40 secs. Fan continues to run for another 20 secs. then everything is off. I have cleaned light channel on the lens and prism. 26 volts to LIFI measures 25.8. Do you have a solution to my problem. Thanks.
  • dianne42 Oct 06, 2010
    Yes, the lamp would not come on at all. Yes I have verified that the power supply is working properly. The voltage with my meter was 25.8. Should that lamp stay on after the TV is shut off. Thanks for your quick reply.
    Dale
    Thanks Tim, I also suspect the OPT unit.
    Dal
    President:
  • 2,777 Answers
So before you replaced the lamp, it would not come on at all, is that correct? And you have verified the power supply is working properly?
Thanks, let me know and I can help
Tim
Posted on Oct 06, 2010
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    My pleasure :) Hmm not it should not stay on like that unless it can sense that it is having heat issues. It sounds like something in the main-board is to blame, the problem with these units is when one thing goes bad it seems to affect many things along the line... usually the main-board.
    I assume there is no way that lamp is getting hot enough for it to need a fan running on it after it's shut off since it doesn't even really get turned on to full brightness?
    Tim
  • Tim Grayson
    I believe you are correct for sure..
    Tim
How to know when a TV DPL lamp is burned
When it do not light up; either the lamp or its coverter is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2016 | Samsung Televison & Video
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic tv model pt-50LC14 will not turn on
First, turn off the tv. Once the fan has stopped, unplug the tv. Remove the front cover from it latches (takes up most of the area below the screen). On the left is the lamp door. One screw holds the door. Remove lamp door. Looks like one screw holds the lamp assembly. Loosen screw and remove lamp. Lamp may be hot if the set was running before you began the lamp replacement.
If you have a new lamp assembly, reverse the process. If a new lamp without assembly, change lamps. CAREFUL. No fingerprints on the new lamp. The oil in the fingerprints will shorten the life of the new lamp.
Reset lamp hours in the menu when done.
Sep 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
