Question about LG WM-2277HW Front Load Washer
Is part number 5221er1003a is this the cold water valve for model# wm2277hw
    President:
  • 1,554 Answers
You are correct. Cold water inlet valve assembly for LG WD-2277HW is part number
Posted on Oct 07, 2010
  • Jahn27
    Jahn27 Oct 07, 2010
    You are correct. Cold water inlet valve assembly for LG WD-2277HW is part number 5221ER1003A.
    The first post looks messed up, some parts are missing and I can no longer add the links I posted.
LG front loader washing machine, model number WM1814CW, won't dispense fabric softener. I need the correct part number to replace the cold water valve
part number 5220FR2006H for the single valve and part number 5221ER1003A for the triple valve. I have both parts in stock and can ship you either you need. The single valve is $28.99 plus shipping and the triple valve is $43.03 plus shipping. You could have it in 1 or 2 days. Thanks Mike
Anderson Appliance 865-945-3808
Sep 16, 2013 | LG WM1814CW Front Load Washer
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a leak in the cold water value of my LG WM2016cw washing machine. I am in need of a part number to order same.
That should not be too hard to find Click here=>Your part number is 5221ER1003A You can find your part here=> 5221ER1003A Water Control Valve
If you need additional help feel free to ask me, Thanks Sea Breeze
Oct 12, 2010 | LG Washing Machines
I've got a leak in my LG WM2277HW coming from the valve inlet (I believe part 5221ER1003A. Anyone else experience this issue? Seems like I can simple replace the part? Thanks!
Yes, I've had this and had to replace the valve assembly, fairly easily fixed once you get the part, and after you discover that the top of the Washer comes off by unscrewing and removing the screws and hinges at the rear top of the Washer and then sliding the top back, away from the front (I had to jar it fairly hard). I hope this helps.
Aug 14, 2010 | LG WM-2277HW Front Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
  • Part for Model# WM2277HW
  • Part# 5221ER1003A
( ) indicates recommended quantity Valve assy, inlet
Apr 12, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
471 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
