Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro 4218 avl, starts (sometimes) then dies, smells like its flooded? New spark plug, fresh gas, still no luck keeping it running, any clues? thanx
    Champion:
  • 248 Answers
May be choke problem,about 20.00 for repairman to fix
Posted on Oct 08, 2010
I have a poulan 4218 chain saw will start but when i pull throttle it dies, open gas cap and gas sprays out
There is a air/fule ratio valve on the side of the carbarator it's adjustable with a flathead screwdriver. Turns this all the way in clock wise then back it out 1 1/2 turns counterclockwise. Once the equipment starts you may have to make some slight adjustments. For a person that dose not know making these adjustments can be difficult. One tip I can give is once it starts you should hear a trickling sound that sound normally means it's in its correct adjustment.
Check a few thing before you do any adjusting.
Check that your exhaust is not clogged dirt dobbers tend to make nest in the small hole.
Check that the fule filter and lines are in good working condition.
Check spark plug or replace.
And replace any old gas. Gas these days has a poor quality and shelf life. Gas that goes beyond 30days should be replaced. Also try to buy non Ethanol gasoline
also check the air filter. If these things check out ok then proceeded with the adjustments. If it still won't run correctly you may need to clean the carberator. Let me know if you need any additional help.
Thanks
Jul 23, 2016 | Poulan Pro 18" Quick Adjust Chainsaw Bar &...
40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to remove chainsaw clutch in poulan pro 4218 avl
you have to buy a hard plastic plug which you place into the spark -plug hole. they are inexpensive. Be sure to get the right one with the proper thread.
You then remove the bar and chain. Next, using a socket and wrench you turn the clutch assembly clockwise. (as opposed to counter-clockwise). It will loosen up . then you remove the clutch and install whatever you want. Leave the plug in until you are finished then install everything and tighten up the clutch fairly tight. Do not over tighten. You may break the piston. Turning the clutch thread clockwise this time.
Nov 25, 2011 | Garden
I have a poulon pro 42cc saw that wont start. dont think its getting gas cuz i tried to flood it with the primer but no gas on the spark plug.
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Aug 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
416 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
