I have a 50 inch plasma tv that goes black after a few minutes of watching it. I can still hear the channel but the picture goes black. I have checked all connections and have switched out the cable box too. What could cause this problem. At times it has been slow to switch channels recently too.
  • 1 more comment
  • rich_patty_c Oct 06, 2010
    The tv is on again I let it sit for a while and has been on for about 15 min without going black. It was working all day so I am not sure why this is happening. I have noticed too that when changing channels it has been taking longer than it used to and I often see a no signal sign floating around the tv lately. I assumed that was the cable box not the tv doing that but I am unsure. Could it be anything else but the boards? And how hard is it to change the boards? Can u let me know where to find the parts too?
    is the board expensive ie. cheaper to buy a new tv or fix it?
    Thanks thought so. Do u recommend plasma or LCD
    President:
  • 2,777 Answers
Yikes that's a nasty one.. a couple things could cause this problem but by far the most likely is the video board of the TV starting to fail. You may be able to reset it by just unplugging the TV from the power source for a good 2 minutes, then replugging it in. If it doesn't you will want to try to replace the board (if you are capable that is...) and go from there. If after replacing it, it still does the same thing, then return that video board and get a mainboard for the TV, although that is much less likely. But between those two parts you should be good. Let me know if you want me to try and track down the parts for you. If you do please include the make / model of your plasma TV.
Thanks
Tim
Posted on Oct 06, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    There is not much of anything it could be but those boards... When you change channels does the sound change right away or is it just as slow as the video? If it's just as slow it could still be one of the boards, but may be your cable box as well. You could always try that cable box on another TV if you have one, to verify it's not the cable box.
    You can get the parts from www.partstore.com
  • Tim Grayson
    The board is expensive even to do the repair yourself. Not quite as much as a new TV but definitely not worth it to try and repair in my opinion. It will still be very expensive, and for whatever reason in plasma tv's when one part goes it seems to start a chain reaction... weakening the rest of the components. So chances are some other part will fail sooner than later and you will be back in the same boat. By the time you get it fully up and running you will definitely be in more than just a new TV would have cost.
    Thanks
    Tim
  • Tim Grayson
    I do still recommend plasma's, Panasonic as well, they are extremely reliable and top notch quality. I am not sure what brand you have here but I would bet it's probably not a Panasonic, and if it is it's probably quite aged. Either that or somehow you happened upon a bad batch, which I've only seen on a small handful of occasions. By far Panasonic is the way to go I feel.
    Tim
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV Flashed HDMI
check samsung web site for firmware upgrade, or use component cabling, which is HD also
Jul 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
