Question about Comfort Zone CZ7007 Oil Filled Electric Radiator Heater
The comfort zone heater, model # CZ7007 when i turn it on it's making the clicking sound like it's on but the light is not on...what could be wrong?
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
Posted on Dec 05, 2009
SOURCE: how do you turn on
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Posted on Jan 14, 2011
  • 381 Answers
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Posted on Jan 15, 2011
I have been using my heater in the garage to prevent my water pipes from freezing. It just quit working today. The lights do not light and it will not heat any longer. What happened and what can I do to...
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Feb 24, 2015 | Comfort Zone CZ7007 Oil Filled Electric...
Just want the manual for CZ7007 - do not have one
Heaters Comfort Zone from Howard Berger
here is the website for the manual. just look for the model you have.
Google is your friend.
Nov 14, 2014 | Comfort Zone CZ7007 Oil Filled Electric...
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
In the Comfort Zone CZ7007 is there a repaceable fuse & if so is it located above the thermostat inside the control panel cover and where can I find another. No heat from unit or lights in switch but
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
Nov 25, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
Is there a recall on the Comfort Zone CZ7007 heaters? I have two that do not work.
Tell us more--
Mack B
Jan 15, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
Had both switches to ON, with the dial turned to 7 (highest). No lights on, unit is cool. verified outlet is OK, and tried several other outlets.
well obviosly he heater has electrical fault seek electrician, the lights not coming on means electrical fault on heater if new get replacement under warranty if not get electrician to fix for you do not attempt to fix electrical problem if your not a electrician or a restricted electrician, maybe an appliance fixing shop may be your best place to try but it sounds deffinatly electrical
Dec 09, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
My heater is smoking does that mean the oil is burned up or can it be fixed
That is a possibility, but for safety reasons I would recommend that you do not turn it on until you have someone with EXP look at it and see fit they can fix it or not.
Nov 07, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Logo
57 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
