Question about Cell Phones
Plastic earpiece that goes around your ear to hold device in place broke. I would like to buy replacments.
  • 677 Answers
Hi, you can get one from eBay site or you can get it from the makers of the earpiece your using at the moment by going to the site to make inquiries on how to get another one.
Also you can contact the customer service center ofthe makers of that particular product you want .
Hope that helps.
Take care.
Posted on Oct 06, 2010
Tip
Motorola H500 earpiece fix
I've read quite a few posts from people complaining about the H500's earpiece being too loose and it flopping when they turn their heads. Here is a fix. After wearing mine for two days I was aggravated enough to try and find a solution. I love the H500 and didnt want to give it up,but the dang thing WAS loose... so :
1. Take the earpiece off just as if you were going to make it as if you would use it on the opposite ear.
2. Notice the sharp bend at the top of earpiece.That is where we will make the adjustment.
3. Get a candle or have a friend to hold a lighter steadily for you
4. Run sharp bend of earpiece thru the flame (DO NOT HOLD OVER THE FLAME) paying attention to the plastic,when it takes on an oily smooth look it will be warm enough to GENTLY push the two ends towards each other to tighten the hook shape. Run the earpiece under cool water when desired shape is reached and make sure plastic is cool. reattach the earpiece and place on ear.
5. Shake head side to side and that baby "shouldn't" budge at all. if it does adjust a little more using the above steps.
I hope this helps as it was one of the biggest gripes out there.
on Feb 04, 2008 | Motorola Mobility Bluetooth Hands Free...
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
Oct 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
How to open earpiece of UrbanEars Medis earbud
I have a pair of marshall minor headphones. They are essentially the same headphones, very similar design if not identical. I had a short occur just where the cable enters into the ear piece, i was devastated when this happened. they are a good pair of headphones and i didn't want to have to shell out on another pair.
To open the earpiece, i first removed the silicone ear-click thingy. if you look in the recessed space where this fits, you will notice a clear join between the two pieces of plastic. I inserted a razor blade into this join and after very little effort i managed to separate the two halves. In doing so i actually poked the back plate off as well, i did actually try to get this off but didn't trust myself enough with the razor blade to continue.
there is another layer of plastic covering the circuit board in the ear piece, which again i would attempt to remove via the recess where the silicone ear-click piece goes. i only had a short in the cable so i didn't go as far as getting to the circuit board.
the whole earpiece consists of at least four main pieces of plastic which are held together by a series of plastic pins. with a little Araldite/ strong superglue you would never know i had opened the earpiece.
i can't believe there is nothing online about fixing these headphones. it's a shame, they are good headphones which have now been saved from the bin.
Nov 14, 2012 | Urbanears Medis Earphones
Earpiece holder around ear seperated - soft rubber from plastic.
If you go to your cellular providers retail location, they have a customer service desk for repairs, etc. they will have parts. Hope this helps
Jun 26, 2009 | Motorola Mobility H700 Wireless Headset
Slft earcup on QC3 broke off
They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Apr 16, 2009 | Bose QuietComfort 3 Acoustic Noise...
Cracked green piece that holds earpiece on skullcandy headpones
This you can warranty. they will give you 1/2 off on a new pair but at least you can get that.
Dec 19, 2008 | Skull Candy (NNTN5751) Headset
PAIRING WITH EARPIECE
This is how mine goes(with Plantronics PULSAR P590)
1--turn on bluetooth on your phone
2--select hands free
3--select add-(the (phone will start looking for devices)
4--start with earpiece Power OFF
5--then hold call botton and keep it pressed while turning on the device
[the device may flash blue (indicating bluetooth) the phone should then be able to sense the earpiece device and display the device name on the phone screen.]
6-highlight the device on the phone and select [the phone will reply with a pass key code request] enter "0000" end hit select/ok [your earpiece is now added to your phone]
7-your earpiece is now set up. [Ensusure that bluetooth is ON on your phone first] To activate the earpiece in the future turn it on and press the call button. This may help.
Oct 23, 2008 | HTC Touch P3450 Smartphone
Changing earpiece
•First take your  device and hold it vertical.
•Looking at the earpiece that ressembles somewhat Alladin lamp, it's tip is positioned either at past 20 (for right ear) or before 20 (for left ear).
•Depending if it's one side or the other, you should turn the earpiece clockwise to 30 or counterclockwise to 30. So the "tip of the lamp", which is the ear channel of the earpiece in fact, is indeed at 30 past the hour.
•Then pull it out with a round motion downward, assuming the upper part is the blue light.
You can then change the side of the ear wire and or the earpiece for a different size supplied by RIM when you bought the device. I don't know how/where to get new earpieces. They don't seem to sell them separately...which is rather frustrating considering the price they sell this device!
Sep 03, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
Bluetooth repair
i have a blue tooth motorola h350 and it just quit working it's under a year old can you get me the 800 number so i can get it replaced
Dec 10, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
