Question about Samsung LTN1535 15 in. HD-Ready LCD Television
Samsung 15" ltn1535
My tv is acting like it is not receiving input from the dvd player. It is properly hooked up with the a/v cable but is only showing a blue screen while the dvd player continues to run. I did notice the tv was unplugged when I returned home. Could something have been reset? What should I try to do?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey mcca,
In many cases, blue screens on TV's can be the result of the TV being in the wrong video mode or another device (like an attached VCR) being on the wrong station.
First, I would suggest testing to make sure that your TV is in the correct video mode and station. Depending on how many devices are directly connected you to your TV, you may need to cycle through one or two video mode settings using your remote control before the DVD menu can be displayed. Typically this can be done by pressing the "Menu" or "Input" button on most remote controls, but you may wish to refer to your owner's manual for instructions how to do so with your specific model TV. In some cases, the primary video input station is even set to channel 3 or 4 by default.
If you are sure that the TV is on the right input setting (and your DVD player is connected to a VCR), I would next suggest making sure that your VCR is on the right channel. Many VCR's will also require that the channel be set on 3 or 4 in order to display any images being sent through them by a secondary device, like a DVD player or video game console. Additionally, it may even be necessary to change the input setting from "TV" to "VCR" to display signals from an attached device. Again, you would need to refer to your owner's manual documentation for specific instructions.
Lastly, if you use an RF modulator or video signal switch for any devices in your home theater, you may want to make sure that they are on the correct settings.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 03, 2008
My dvd player is hooked up to the samsung receiver. I am using two remotes, one is the cable box remote where I hit tv and power and then cable and power and then the red power button on the samsung remote...
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
May 16, 2011 | Samsung HW-C700
How do u hook up the dvd player and dish network to your tv
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
DISH Network Customer Service
Dec 10, 2010 | Sanyo DWM400 DVD Player
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Cant figure out to hook up keeps saying no signal with hdmi cable to tv and blu ray put in
What kind of TV are you hooking the dvd player up to ? You may have to go into the TVs menu and set the input to the proper resolution or input style to see a picture. The dvd outputs a 1080i and if the TV is set to 720p it may not show a picture, the dvd output can also be changed to match the TV.
Sep 06, 2009 | Samsung BD-P2500 Blu-Ray Player
I have a 50 incch samsung tv with samsung surrond sound/receiver/dvd player. I have no voices when we play a dvd but the music plays what is wrong
You need to have the audio from the DVD player hooked up to the same input path on the receiver.(if your running video thru the receiver) DVD audio should be hooked up to either an analog input (RCA cables) or Digital input like Digital Coaxial or Optical. Next to where you are plugging in these cables will be writing like "DVD optical" or "DVD digital". Then, make sure you switch the input of the receiver to "DVD" then it should work fine. If you still have problems post a comment and I will help some more. Hope this helps
Jun 14, 2009 | Audio Players & Recorders
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
I am trying to hook up my tv to my receiver, I have a dvd vcr combo,and cable box
Audio: There should be a set of audio outputs on your TV. Connect those to the AUX inputs of your receiver. When you turn on your receiver, set it to AUX. Set your TV volume to approx 1/3 and adjust the volume on your receiver. There's probably a menu section on the TV to turn off your TV speakers so the sound will only come from your receiver.
DVD/VCR (I'll call it DVD from this point forward): Connect the video (yellow) output from the DVD to the "video input" on the back of the TV. Connect the audio out on the DVD player (red) to the red audio input on the back of the TV, then do the same with the other audio (white). When you want to use your DVD player, you'll select "input 1" as the input on the TV.
Cable: Your cable box probably has numerous output types. I have the cable box hooked up to both the DVD player AND to the TV; one output type going to the DVD player and another output type going to the TV. I like to use the HDMI output from the cable box to the TV, and the composite video from the cable box to the DVD.
Hope this helps. Let me know if you need more info.
Mar 18, 2008 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Samsung LTN1535 15 in. HD-Ready LCD Television Logo
156 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
