Question about Intermec EasyCoder PM4i Printer
Error message is "Out of Paper". how to solve this error?
  • 386 Answers
Hi Good day.. This error message means you have ran out of paper, you must must load a paper and then click continue, the printer should print now..
Regards:
JR
Posted on Oct 07, 2010
  • Fingeri Jul 28, 2011
    Not help,loaded several times paper,put on/off etc.still same paper out error..what is next step??
crayzeetrayn
  • 837 Answers
SOURCE: Cannon MP600 error message U052
hi there,
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Posted on Jan 16, 2009
  • 214 Answers
SOURCE: message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Posted on Apr 21, 2009
  • 1684 Answers
SOURCE: The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 19, 2009
MalKontent68
  • 748 Answers
SOURCE: While printing with OKI C5600 very often error
Try cleaning all the paper feed rollers you can access, both from the bottom (paper tray pulled out) and from the front, behind the front door. It might be that the sheet is not fed properly and doesn't reach some sensor in expected time, thus the errors.
Also clean the separator - it's the small area on the paper tray where the feed roller touches; it needs some friction to hold the sheet(s) beneath the one being fed.
To clean use isopropyl alcohol or some kind of residue-free and oil-free cleaner on a piece of cloth or paper towel that does not leave lint.
Posted on Oct 24, 2009
  • 19 Answers
SOURCE: paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Posted on Jan 25, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper tray empty error message
no worries...it could be your drivers are shot..turn off machine, and let it sit for 10 minutes..unplug from computer, turn on, then tray a test page from front panel
Apr 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Our fax has the following error message: Printer
Press
Function
7
monitor key slowly 4 times
6
scroll sdown to SHIPMENT SET
set
wait for the machine to initialize
Nov 24, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
My canon MP210 gives E9 error. How does it solve?
Some of the error codes for your printer,
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
hope it helps
Jun 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error message on 4050n printer "manually feed hp tough letter"
What error message is on the display?
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Jan 20, 2009 | HP LaserJet 4050n Printer
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
Media Jam - Fuser Error
if the paper comes out and you get still this message, then probably you have a wrong paper format or fusing unit solenoid is stuck.
Aug 09, 2008 | Minolta 2430DL Color Laser Printer
Error Message: Lightning Bolt A
Remove the tray and check the wire you mentioned, that it is connected to the paper end sensor.
Probably the paper end sensor has its plastic legs broken.
If so, replace the paper end sensor and you will solve the error message.
Good luck and please rate me, thanks.
May 20, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
General error - see your printer Documentation for information about clearing the error.
I solved the problem .. during the ignition printer I inserted a sheet of paper in the printer (side cartridge) while the rollers running. the printer has expelled the sheet and the problem is solved
Apr 09, 2008 | Epson Stylus Photo 925 InkJet Printer
Intermec EasyCoder PM4i Printer Logo
724 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
