What is the make / model of the cam? 2.2 PE doesn't tell me much.
Thanks
TIm
Ok let's start with this, when you first plug in the camera or unplug the camera, does Windows make the little "ba-doop" chime that lets you know some knew device was plugged in or removed? Please confirm.
Thanks
Tim
Oh I see, it's just with the software itself. I seee.... ok what you need to do is run it in XP compatibility mode tp dp that you need to go to My Computer, then C Drive, and navigate to where the 2.2 PE is installed. Probably something like C:\Program Files\Trutech... something like that.
Go there and locate the actual program that it is launching. You can also find where / what it is by going to your start menu list of programs, finding the 2.2 PE and right clicking on the icon you use to open the program, on the main tab it should have LOCATION and will say C:\Program Files\.... wherever it is\PE.exe or something like that. Go to that exact file using the method listed above... then:
Then try to launch it...Right click the executable and click the Properties option.
Select the Compatibility tab.
Select the Run This Program in Compatibility Mode option.
From the drop-down list, choose the operating system you ran before upgrading to Vista.
If necessary, select the option to run the program as an administration.
Click OK.
If it still doesn't work then that program simple will not work in Vista at all :(
Tim
Oh and from the list of options of course you want to select Windows XP
Hoping you saw my other comments?
Tim
I see, well you may want to install XP on that machine and dual boot if you have to, I am seeing many others that have had that problem with version 2.2... doesn't look like it will work with Vista at all :(
Tim
Either that or just put XP on that system... If you want to find out about dual booting (it's pretty tricky but can be done) read this;
http://windowssecrets.com/2008/02/14/01-...
I'm sorry, its trutech webcam 2.2 Personal Edition i can get the 5.0 but it sucks, slow vid and bad vid. Its also called Camarades 2.2 Thanks for any help. 7
Thats not the problem, i use a RCA cam corder its fine and i can use the newer version of camarades. i need to get the older version 2.2 PE to work. When i start the program it trys to start but then i get an access violation.
This may help, here is my webcam site address= http://www.2seventhunders.camarades.com
I had tried that before did it again and there isn't a XP under tab 95-98 2000 i tried them all still get access violation
