Question about Canon imageRUNNER 8500 Copier
I just want to ask if I made a copy long time ago does the document that I copied will be on the copiers memory
  • 1,110 Answers
No it does not. Contrary to some stories out there the copier does not store copies in the memory or on the hard drive. It can store documents that are scanned and stored onto the hard drive. It can also temporarily store backed up print jobs that are stored before being printed such as in high traffic installations. But the answer to your specific question is they are not stored in memory. This is especially true of a somewhat older model like your IR8500.
Thank You for using Fixya.
We are having a contest this month based on customer testimonials. If I have helped you with your free question today please leave a positive testimonial.
Thanks.
Posted on Oct 06, 2010
Hp cm 1312 stopping after five copies. Is my memory too small?
Check what is the size of the documents you print, if the memory is not decent and documents big, it may clog the memory temporarily. Regards, Mike.
Jan 18, 2016 | HP LaserJet CM1312 All-In-One Printer
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
I was copying a fairly large document and at some point the document continued to scan but stopped printing. The memory light is on and the LCD print out reads "printing" but it is not printing.
hello there, Sorry but the question is a bit confusing. Did the document finish copying or it copied half way and stopped? Or you were copying and printing it at the same time?
If you were copying and printing at the same time then the problem is expected as the procedure for printing is considerably faster than the copy process. Simply turn of the entire system either by proper shutdown or by just cutting the source of power to the unit. And this time copy the document completely first before you try printing. This should come up without any hassles.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 04, 2011 | Office Equipment & Supplies
How do you copy front and back?
1. First make sure you are in Copy Mode
2. Load document
3. Enter the number of copies you want using the number pad
4. Press Duplex and "up arrow" or "down arrow" to select 1sided>2sided L
5. Press Start to copy the document.
FYI - if you get an Out of Memory message while making duplex copies, you might need to install extra memory.
Mar 01, 2011 | Brother MFC8890DW AllInOne Laser Printer
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? wgaynair@gmail.com
Jan 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Can a scanned document be retrieved after the fact?
anything you copy or scanned does not store in harddrive...it erase instantly after it sends it or copies it. it's a information security regulation...but if you e-mailed it it should be in a workstation cpu folder.. normally called SCAN folder.
Dec 26, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Canon imageRUNNER 8500 Copier Logo
43 people viewed this question
old marine
old marine
