Question about HP HDX16t Premium Series Notebook
How do i disassemble the hxp hdx16 to replace the lcd
How can I replace videocone integra LCD screen ?
You have to disassemble the TV; fully; to replace it. Should have all tools to disassemble it, and much experience in work too.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 26, 2014 | Televison & Video
Factory reset hp hdx16
How do i factory reset my hd hdx16-137ous premium notebook pc
Feb 28, 2014 | HP HDX16-1370us (NV032UA) PC Notebook
My hp series HSTNN-105C WON'T BOOT INTO THE OS
This indicates a hard drive problem or windows files has been corrupted. If you have a cd installation disc load your operational system, if that fails have the hardware tested for possible replacement.
May 07, 2012 | HP HDX16-1370us (NV032UA) PC Notebook
Hp hdx16 no power
The power supply charger should be checked for correct voltage, If it's dead it will need to be replaced. Remove main battery first, now turn on! if no change, you will need a professional to assess.
Feb 22, 2012 | Computers & Internet
I have an HP HDx16 laptop that seems to run very hot. Is there a way to check this problem or increase the cooling capabilities
If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
Jun 11, 2011 | HP HDX16-1160US PC Notebook
Hello, I recently changed out the motherboard on an HP HDX16-1160US. It booted up just fine, but the video is jumbled/jumping. Is there anything I can do to remedy this problem?
have you double checked your connections sometimes those ribbons dont go in wright even see if your video card is not loose to test this hook up a computer monitor...
Apr 15, 2011 | HP HDX16-1160US PC Notebook
Do imported hxp battrys damage new zealand sold tools cheers
Well, it's highly unlikely as long as it is a HXP 18V Li-ion battery because pretty much all hitachi stuff is imported. The companies HQ is in Japan and so id the largest manufacturing plant. I hope this helps please rate this thank you
Mar 17, 2010 | Hitachi Hxp 18 Volt Li-ion Hammer...
Can u tell me is it better to use diamand core bit using hammer action or rotary only
Diamond core bit works great on either setting, you will get faster results on the hammer action though
Jan 02, 2010 | Hitachi Dv18dl 18v Hxp 3.0 Ah Hammer Drill
Hitachi 24v yfa charger green light
hi
it shows you that the battery is charging.
regards savumihai71
Sep 12, 2009 | Hitachi Hxp 18 Volt Li-ion Hammer...
New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
Does it seems like the new battery takes a charge? If not, then as good as Hitachi's are...it sounds like a defective battery to me. Should be able to warranty for you no prob.
If you have a buddy, check it in his charger. Or possibly try a charger in the store if they have a demo.
Dec 07, 2008 | Drills
HP HDX16t Premium Series Notebook Logo
901 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
