Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I have model # ASD2627KEW side by side. I changed the water filter in the fridge but the red light still says on.How do I get the ligt to turn green. Thanks
HVACRH20
  • 237 Answers
SOURCE: Water Filter
Look up to the upper right corner of the frige section and you will see a long white tube with a small latch on the end. Looks smaller than a Pringles can in diameter. Pop the latch down and the cover will lower. Hold the back as much you can and twist the filter about 1/4 turn counter clockwise and it should pop out. Once you install the new filter run a couple of "KoolAid" sized pitchers of water through the door to get all the air out of the line.
Posted on Nov 10, 2006
SOURCE: water filter
The red warning light has to be reset manually - by pressing the Ice Type and Child Lock buttons together for 5 seconds. As for the taste, check the flow direction is correct on the filter and run a few litres of water off.
Posted on May 13, 2007
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
  • 1073 Answers
SOURCE: AMANA SIDE BY SIDE
what is the model?
Posted on Apr 17, 2008
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
Posted on Aug 08, 2008
Amana asd2627kew side by side - lights not working on water dispenser
Your Dispenser may locked or any of it futures there is lock prevents ice or waterfrom being dispensed is well light to operate in sertain way, download here download here complete manual it shows on it how to lock and unlock these futures. Iand I think it is on page 17, to find words quickly on these 112 pages press Ctrl + F and type word you looking for "light" for example. hope that helps!
Nov 04, 2013 | Refrigerators
Red light
Try firsd doing a complete defrost, leave fridge unplugged at least 24 hours
May 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
What is red basket light on for says filter above it
The red and green basket lights are your filter status. it works on a timer from when the fridge is new or reset it. when you change a filter or just want to get rid of the rid light and make it green again, press and hold the ice type / change filter button for about 5 seconds. it will then go back to green. It will stay green for 6 months from that time when it will go red again.
May 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water Filter Red Light
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Jan 12, 2009 | Jenn-Air JCD2290HES Side by Side...
Daewoo refrigerator water filter red light still on after replacing the filter
Ivan
Oct 08, 2007 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
