Question about Thumper Mini Pro 2 Massager
Thumper mini-pro:switch does not working - Thumper Mini Pro 2 Massager
  • 2,272 Answers
This happens when the internal connections of switch are faulty or broken.
The unit needs to be opened and the panel behind the switch needs to be cleaned and the connection should be rewired.
Also check if the switch moves freely. if its jammed or stuck down then clean the switch surrounding and refit the switch. Its easy to do job and you wont require any special tool, Just a basic screwdriver is enough.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 06, 2010
Where can i get a thumper mini pro repaired?
Actually, you can remove the switch without opening the case, by simply carefully prying off the switch (which is actually a switch cover)
and then pushing the retaining clips of the "real" switch itself until it comes out. Then inspect & clean, and see if that solves your problem.
Another possible cause might be blown circuitry in the over-heat limiter.
May 20, 2014 | Thumper Mini Pro 2 Massager
THE TWO MASSAGE BALLS BROKE INTO ON THE THUMPER MINI PRO 2, HOW CAN I GET A REPLACEMENT
Call the company. They are very good for replacement parts, if you plan on DIY: Otherwise, they discount a replacement unit.
Apr 08, 2014 | Thumper Mini Pro 2 Massager
Thumper mini pro stopped working while in use?
Did it ever restart? If your'e not aware, there is an overheat prevention that will shut down the unit after prolonged use.
Apr 05, 2014 | Thumper Mini Pro 2 Massager
Take apart case to repair switch
Atleast on model which I own (~6 yrs old), there is no need to take apart the case for switch removal. Simply pry the switch cover off (gently) and switch will then slide out for cleaning & evaluation.
Feb 02, 2014 | Thumper Mini Pro 2 Massager
Where can I get the purple plastic pivoting assembly for my mini pro2 thumper massager
best to call the company & see if they have it available as a repalcement part.
Sep 06, 2012 | Thumper Mini Pro 2 Massager
Thumper will not massage
clearly you'll have to disassemble to determine the problem (if not done already). For instructions, check 'thumper repair'
Apr 24, 2012 | Thumper Mini Pro 2 Massager
There is a long delay before the massager will acturally start to vibrate. Is this something that can be repaired?
The switch contacts are probably dirty. If you pry off the switch (actually it's a cover), you will see the actual switch underneath. There are several sets of contacts that control the speeds. Use a cotton swab wetted with 91% rubbing alcohol and clean the contacts. This made my Thumper work like brand new again. My is an older unit, and has open switch contacts. The newer models may have a different switch. This procedure was recommended to me when I called Thumper about my Mini Pro 2 not working properly. You can reach them at 1-800-848-6737.
Jul 12, 2010 | Thumper Mini Pro 2 Massager
Adjustable speed not functioning
The switch contacts are probably dirty. If you pry off the switch (actually it's a cover), you will see the actual switch underneath. There are several sets of contacts that control the speeds. Use a cotton swab wetted with 91% rubbing alcohol and clean the contacts. This made my Thumper work like brand new again. Mine is an older unit, and has open switch contacts. The newer models may have a different switch. This procedure was recommended to me when I called Thumper about my Mini Pro 2 not working properly. You can reach them at 1-800-848-6737. They are very nice people,and can probably help you fix the problem.
May 23, 2010 | Thumper Mini Pro 2 Massager
Disassemble to repair
I just decided to try to fix mine. There are all together 5 screws. The two on the handle are covered with plastic caps which can be pulled out by sticking a duct tape and pulling it up. The other three screws are in the thumper head and are covered with the purple violet rubber piece. I removed it with my fingers. There are also two plastic bolts in the head of the thumper opposite to the handle. I removed them by using a sharp knife to loosen them and pulled with pliers.
I purchased two thumpers over time and in both the switch failed. I see that the switch in the handle is linked with the underlying mechanical switch by a very thin plastic piece. What a miserable design. That piece broke off in both thumpers rendering them unusable.
Good luck. Artur
Dec 31, 2008 | Thumper Mini Pro 2 Massager
Thumper Mini Pro 2 Massager Logo
432 people viewed this question
Top Thumper Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
