Question about Dryers
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold again and won't get hot anymore?
    President:
  • 1,430 Answers
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Posted on Oct 06, 2010
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
Maytag Gas dryer not heating, Model #MDG8600AWW
Called Maytage directly, information is free. Thanks anyway
Jan 13, 2010 | Maytag Dryers
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Gas Dryer not heating
Check the thermal fuse on the heat vent canister.
Check the glow bar ignitor on the gas valve.
Mar 03, 2009 | Maytag Dryers
Maytag dryer mdg508daww
sounds like you need to replace the coils on the gas valve. there are 2 of them, they are rond and black
Dec 31, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Dryers Logo
280 people viewed this question
Top Dryers Experts
