Question about Maytag MZD2766GES Side by Side Refrigerator
We find water on the floor in front of our Maytag fridge. Any suggestions?
  • cabizer Oct 10, 2010
    Once we wipe up the water, it's usually dry for hours, sometimes a full day. Then we see another puddle about a foot around on the floor again.Fridge doors have not been left open.We cleaned the whole back of the fridge thinking something might be blocking something.
  • 1,711 Answers
First you should check the water pipe if there is a leak. Since you see the water at front then check under the freezer door you will see the water pipe going up to water dispenser and ice maker. Check it with a flashlight.
If it is not leaking from the door then pull out the fridge and check at the back all the way the water pipeline coming from the mains going up to the filter and then down to the solenoid valve.
Another way is shut off the water from the mains and check after a while if you see any water or not.
If everything with water pipe is ok then you should check the defrost drain pipe on the back of the freezer. Check if you have too much ice. If yes try to melt it either with a hair dryer or using hot water.
If there is not any ice build problem then you can use some water from the freezer side and check if it arrives in the drain pan which is under the compressor on the back of the fridge.
If you don't find any problem with above check if the door gasket is faulty so there is air leak from freezer which mean you will too much ice build in the freezer but at the same time condensation to the outer of the freezer from cold air leak and this will create the water on the floor.
These are the main possible faults for your case.
Posted on Oct 10, 2010
    President:
  • 4,070 Answers
Hi! Just a thought... Once you wiped the floor are there still drips of water? Someone may have just left it open or spilt something on the floor.
Mdz2766ge maytag fridge; water puddles on floor when defrost kicks in
Check the drain tube from the defrost coil near the evaporator to the drain pan.
Jan 29, 2014 | Maytag Refrigerators
Having thermostat problems in my Maytag fridge/bottom freezer. Pulled the fridge out and vacuumed everything. This am the copper coil on the back outside is leaking water drop by drop. The coil is not hot/...
The copper coil on the back comes from the compressor and is what makes the fridge cold but it is filled with gas. They can condensate and drip water but this isn't usually enough to notice, or cause damage. I would actually suggest looking again to check the exact source of the water. Be aware that some water from the defrost cycle is supposed to drip into the evaporator tray at the back.
Jul 10, 2013 | Refrigerators
I have a water leak inside of my maytag fridge and it leaks out onto the floor from the inside. What is the couse of this problem?
Have you checked to see if your condensation tray is too full? The tray will be located at the bottom of the fridge and should slide out easily.
Feb 19, 2012 | Maytag Refrigerators
I have ice on the bottom floor inside the freezer and. water on the floor outside by the front of the freezer door on the hinge side
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice built up floor of freezer compartment. water on floor
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Maytag MZD2766GES Side by Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
