Question about Kenmore Microwave Ovens
WERE IS MODEL NUMBER ON KEMNORE RANGE? - Kenmore Microwave Ovens
  • 5,911 Answers
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Posted on Oct 07, 2010
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Need a over the range microwave with height of 14"
The first thing I'd do is contact the manufacturer of the old oven and ask if they have a current "drop-in" replacement model to replace your old one's model number.
Otherwise, you'll have to visit various manufacturer Web sites and dealers to check out their specifications.
Oct 18, 2012 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
I have a GE Profile Spacemaker PVM 2070 SMSS and the button pad needs to be replaced for the vent and lights. Can this part be purchased?
Sadly on the 2070-series models, GE does not make separate parts available for the controller.
Only the control panel subassembly is available, and these range from a few hundred to several hundred dollars, depending on your full model number.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download GE owner's manuals and installation instructions here.
Jan 17, 2011 | GE Profile Spacemaker Over-the-Range...
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Range light and oven vent fan
This usually indicates damage to the circuit board of the control unit assembly. We repair these control units nationwide for only $32.50 postpaid. If you decide first to remove or replace the bulbs or check the sockets or wiring, please unplug the microwave first. Failure to do that is usually how the boards get damaged. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can usually find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 BUT - I don't recognize NN-2501 as a valid model number. Could you confirm that? Thanks!
Feb 18, 2007 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
