Question about HP Photosmart 945 Digital Camera
I have an hp photosmart A433 portable and the zoom lens is stuck so it does not open...needs service...i am in new york city where can i go?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 07, 2010
M425-435
Sorry i could not understand you !!
Mar 19, 2013 | HP Q7032A Photosmart A433 Portable Photo...
Camera lens stuck - how do I get it to work
This problem can be difficult to resolve without having the lens gearing mechanism serviced. However, I have written a FixYa Tip on this issue containing several approaches that have been known to work.
Please view it from this link
Many thanks for using FixYa.
Nov 07, 2009 | HP Photosmart M425 Digital Camera
My camera wont turn on.
ur lens strip is broken by using in out lens dont use zoom it crecks ur belt. now send for service
Jun 18, 2009 | HP Photosmart M22 Digital Camera
Nikkor AF 18-135 lens won't retract fully
The Zoom ring maybe stuck on something, or not aligned properly Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Jun 01, 2009 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Lens stuck in the extended position
i don't think the lens mechanism can be repaired, it may need to be replaced, usually for about 50% of what you bought the camera for. there is a company in new york that carries parts for small digital consumer cameras like this : Camera Repair NYC
Mar 31, 2009 | HP Photosmart M537 Digital Camera
Camera error
Your lens is not communicating properly .
It is stuck it is due to mechanically problem you are having this error.
Jan 24, 2009 | HP Photosmart 935 Digital Camera
Hp photosmart r742-lens error
Press the lens till the little doors close but not at all, i just fix it these ways 2 min ago! I SWEAR, just press it with a little hard and cross ur finger =D it work for me!
Aug 14, 2008 | HP Photosmart R727 Digital Camera
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Zoom lens stuck
Evidently the mechanism is damaged by a knock or dirt has entered the system. There is no self repair remedy Contact the HP customer support site for further advice
Jul 28, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 945 Digital Camera Logo
60 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
