Question about Alert Driveway Patrol Infrared Wireless System
I have a driveway patrol that wont stop beeping. i have covered up the sensor and that doesnt work. what to do
  • 1,606 Answers
First check the power supply for each unit. A low battery or bad filter capacitor (AC power) can cause all sorts of misbehavior.
Do you have an infrared camera or other IR detection device available? (Sometimes you can improvise by removing the infrared filter from a Webcam.) Check to see if the IR emitter is working. Another possibility is that the sensor or emitter cover is dirty. Also, check whether there is something in the field of view that is causing the false alarm. Moving the sensor unit is one way to eliminate this possibility.
These are the "easy" preliminary checks. If you haven't found the problem with these tests, it's time to get out the instruments and check voltages and waveforms.
Posted on Oct 06, 2010
My td42 it gu y61 nissan patrol wont start when hot, replaced glow plug relay and temp sensor , will start whhen hot if you disconect temp sensor
Having the same problem mate! It's to do with the "quick glow " circuit I'm trying to find the exact control unit that is at fault
Sep 01, 2014 | Cars & Trucks
How to replace a fuel filter on a nissan patrol st turbo diesel 2000
not sure what year model it changed over but it either unscrews from the filter housing(and the water sensor in the bottom of it),or you undo a cover and it is in a canister
May 30, 2012 | 1989 Nissan Patrol Wagon
Have1989 nissan hardbody and carbarator runs a steady stream of fuil when trying to crank doesnt stop. Whats wrong
Hi, the likely problem is a stuck float valve. If you tap with a small hammer on the carburetor float bowl near where the fuel line attaches, you may be able to reseat the valve, at least temporarily. As a long term solution, I would rebuild the carburetor. In the process, you would get a new float valve. Please let me know if you have more questions, and thanks for using FixYa.
Apr 02, 2011 | Nissan Hardbody Cars & Trucks
Sensor light stays on all the time
Unplug the unit.Take some windex glass cleaner spray on the sensor to clean it.Wait about an hour,replug the unit,should solved this problems.
Feb 25, 2011 | Alert Driveway Patrol Infrared Wireless...
I there any way to adjust the snsitivity of the motion sensor? Wind blowing seems to set it off
U CAN PUT TAPE ON THE SENSOR IN BOTH DIRECTIONS TILL THERE IS ONLY ABOUT A 1/8" HOLE IN THE CENTER AND IT WILL STILL PICK UP MOTION AS SOMEONE WALKS BY IT. JUST START AT THE BOTTOM AND WORK UP OR START ON THE SIDE TILL U GET IT TO WHERE U WANT IT. I PUT A PIECE OF TAPE ON THE BOTTOM THEN A PIECE ON TOP. THEN A PIECE ON TOP OF THE BOTTOM PIECE SO IT COVERED ANOTHER 1/8", THEN ANOTHER PIECE ON TOP OF THE TOP PIECE AND SO ON TILL I TUNED IT IN TO JUST HOW I WANTED IT. GOOD LUCK.
Feb 10, 2011 | Alert Driveway Patrol Infrared Wireless...
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
ALARM SOUND ABOUT EVERY 5 SECONDS AND i HAVE NOT YET PUT IT OUTSIDE
check the instruction, it sounds like you are getng interferance on the channel its on. the instructions should cover changing it to another channel and avoiding something else triggering it.
Nov 17, 2009 | Alert Driveway Patrol Infrared Wireless...
Alert Driveway Patrol Infrared Wireless System Logo
1,024 people viewed this question
Top Alert Home Security Experts
Paul Bade
Charles Ma
Charles Ma
Five sok
Five sok
Level 1 Expert
Are you an Alert Home Security Expert? Answer questions, earn points and help others
