Question about Apple iPod touch
My screen on my ipod froze it. wouldnt slide to unlock. then it wouldnt turn off. now it wont turn on or recognize to my itunes or charge. it wont do anything.
  • 881 Answers
Press and hold the POWER and the HOME button until you see the Apple logo on the screen.
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email:
sale-47hyk-1863377234@craigslist.org or add me on Skype: ebayseller.ca
Posted on Oct 06, 2010
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
Cant unlock my ipod
What generation? What do you mean, the slide to unlock, or the screen lock? If you mean the screen lock, you should connect to iTunes, because some iPods unlock after connecting to iTunes. Otherwise you should reset it with iTunes. But then all your data will be lost. Otherwise you should try try try. You've got 10000 chances ;-) If you have an iPod Touch, you might mean the slide to unlock screen is frozen. I had that one time, after trying out spoken feedback. After that it locked the screen and the touch screen wouldn't work anymore. I couldn't do anything anymore, not unlocking, not turning off spoken feedback, not even turn off the iPod. I was lucky to find there was an update for the iPod so iTunes turned it off. Then it responded also again.
More details next time please!
Jun 22, 2010 | Apple iPod nano
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
Dec 17, 2009 | Apple iPod Photo MP3 Player
Why is my iPod touch disabled for 5009752 minutes
The iPod touch is disabled when the incorrect unlock code is entered too many times. The time the iPod makes you wait increases each time an incorrect unlock code is entered.
There are two ways you should be able to unlock the iPod.
First, connect the iPod to the computer it was last synced with. After iTunes recognizes the iPod, you should be able to enter your unlock code and unlock the iPod.
If the first method doesn't work or you don't remember your unlock code, then do this:
1) Turn the iPod off.
2) Hold down the Home button and connect the iPod to the computer it was last synced with.
3)Release the Home button when the iTunes image appears of the iPod's screen.
4)Wait for iTunes to recognize the iPod and then follow the onscreen directions to restore the iPod.
If neither method works, you will need to contact Apple Customer Support.
Nov 25, 2009 | Apple iPod touch
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
Doesnt turn on.
This same thing happened to me. I was playing fantastic contraption and my ipod screen just went black and wouldnt turn back on. When I plugged it in to a charger, it made that charging noise, but wouldnt turn on. SOLUTION: try holding in the sleep/wake(power) button, and the home button at the same time for about 15 seconds or until you see the white apple logo. That worked for me, hope you get it fixed.
Flaming Llama
Jul 04, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
Apr 19, 2009 | Apple iPod nano MP3 Player
Does not respond to touch
Take the battery out for 1 minute, and put it back in and try again.
Mar 02, 2009 | Apple iPod touch
Apple ipod nano blue 4gp
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 16, 2008 | Apple iPod nano
Apple iPod touch Logo
306 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
