Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Posted on Dec 28, 2010
My duo therm furnace thermostat runs for a fem minutes then stops. I have to restart to get it to run again.
It is provably the high limit switch. Take a look on google for troubleshooting the high limit switch on a furnace.
Mar 18, 2018 | Heating & Cooling
I have already changed the heat sequencer&limit switches still no power to the sequencer and I'm getting 37voits @ thermostat
37 volts is way to much. Verify your transformer is set to proper voltage, 208 or 240. Then verify 24-27 volts on r terminal. Wire nut red green and white at stat to bypass tstat, then check low voltage to sequencer. If its anything other than 27 you have a bad wire or possibly a bad board. Not sure how your power gets to sequencer. Make sure you are testing sequencer on each side of coil, power and common, not power to cabinet. May have issue in common wire. Or try both P&C OR P TO cabinet
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 16, 2016 | Heating & Cooling
My central electric furnace eb15b heats up up but the blowers not turning on?
Most likely it is the sequencer that is bad. Try turning the fan on with the thermostat. If it runs in "on" and not in "auto", most likely it is a bad sequencer.
Mar 14, 2014 | Heating & Cooling
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
My honeywell thermostat will not let the fan blow if it's on automatic
My central heating is on lockout and the burner is with red light
A sampling of various codes on a furnace
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your Goodman furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2010 | Heating & Cooling
I have a Goodman airhandler model #A24-10, serial #9305071035 and can not get fan motor to cut off except by turning off breaker. Ihave replaced two sequencers and checked out all 24volt wires to...
https://www.wedclix.com/wp-content/uploads/2017/12/aept-aepf-thermostat-control-wiring-central-air-and-heat-diagram.jpg
Let me know if this is the diagram u looking at?
Jan 05, 2018 | Goodman Heating & Cooling
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Air conditioner/furnace squirrel cage fan remains running when th
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Dec 05, 2008 | Ruud Central System Air Conditioner
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
249 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
