Question about Xerox Phaser 8560DN Laser Printer
What maintenance kits can I use in my Xerox Phaser 8560DN
  • 2,296 Answers
Standard-Capacity Maintenance Kit - 108R00675 - 10,000 pages#
Extended-Capacity Maintenance Kit - 108R00676 - 30,000 pages#
Posted on Oct 27, 2010
Xerox Phaser 8560DN error code 07,010,43
Sadly, Xerox says that this means "Power off the printer and contact support". Phaser 8560 Support Drivers
However, there is something about "opening the pivot plate", it's Greek to me, but google it and see if you can't reset the brain in the printer and get it back to life without an expensive service call.
Aug 23, 2014 | Xerox Phaser 8560DN Laser Printer
ERROR CODE PHASER 8560 07,010.43:69551 Replaced Maintance kit
. they replace a certain number of pages printed by the manufacturer data
maintenance kits are easily user installable and come with a fuser assembly, transfer roller, and pickup, or feed/separation rollers.
Apr 11, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox printer 8560n won't print
First download and install printer's driver ..click here Select your operating system and language. Next try to print the configuration page ..--> Press the [Up] or [Down] arrow button on the Control Panelto select [Printer Setup] on the Display Screen, and then press the [OK]button. Press the [Up] or [Down] arrow button to select[Configuration Page], and then press the [OK] button to print. Press the [Up] or [Down] arrow button to select [Exit], andthen press the [OK] button to return to the Main Menu.
Apr 05, 2011 | Xerox Upgrade Phaser 8560N to Phaser...
Shadow Printing on a xerox Phaser 8560. Have changed the Maint Roller and done the various cleaning cycles
The printer requires a maintenance kit. (95% chance anyways)
I would suggenst the extended life maintenance kit (10,000 page lifespan) part number 108R00676 to correct this issue.
You can usually get these where you get your solid ink cartridges.
Feb 25, 2011 | Xerox Phaser 8560DN Laser Printer
09,008,43:167 error on an Xerox 8560dn
The error code 09,008,43 indicates the ink is not melting into the printhead. Raise the ink loader Top Cover to access the ink blocks and make sure they slide down properly. If this doesn't fix it you gonna have to call Xerox for service maintenance.
Nov 18, 2010 | Xerox Phaser 8560DN Laser Printer
Xerox error code 08,009.43
That is a media path motor fault.
That is the paper path motor and gear assembly on the left side of the machine looking from the front.
Since it happened during a cleaning session, I would suspect that the maintenance kit may just be stuck out of position of the head maintenance clutch may be bad, Here is that part number
033E05190
Head Maintenance Clutch
Jul 02, 2010 | Xerox Phaser 8560DN Printer
Light stripes
Sadly the print head probably failed. Thats not uncommon. Yeah, even at 7000 pages.
If it is just one color, the problem is a jet. If it were a blade or maintenance kit, the problem would be with all colors.
You have some blocked jets. If you have run eliminate light stripes 3 or 4 times and it hasnt cleared, chances are the print head would have to be replaced.
May 21, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox 8560 printer error message
That is a fault in the process drive motor area.
It is the assembly that operates the maintenance kit movement.
You may simply have to reseat the maintenance kit.
The motor drive train may also be mistimed. If you have purchased that machine in the last year, there is a one year onsite warranty on that product. If so have your serial number ready and call 1-800-835-6100.
Aug 11, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
91 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
