Question about Western Digital Computers & Internet
How do I install my new hard drive as a slave to get additional storage?
  • 40 Answers
Look your hardisk there in a jumper like blue color or any look at the top of your hard disk where to put the jumper to slave and another hard disk to master. but use this setting if you using one cable like IDE. but if use sata just put your sata cable to sata slot in your motherboard. follow the no. of your sata slot.
Posted on Oct 07, 2010
How do i set a seagate barracuda 7200 hd to slave
you don't need to setup as a Slave drive like IDE drives. You simply install the new SATA drive on an open port and follow the steps in this thread to format the hard drive. This will allow the hard drive to be used as a storage drive or whatever you plan to use it for.
Guide: If you installed a new disk but the system can't see it
May 11, 2014 | Compaq Presario SR1030NX (DW256A#ABA) PC...
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
Have replaced computer. Motherboard dead on old one. Is there any practical way I can get pictures and such from old computer. It will not power up. Thanks
You should be able to tak the hard drive out of the old one and put it in the new one as a secondary drive. There is a good chance, though, that the drive won't fit. If it doesn't, you'll need something like this.
Mar 02, 2011 | HP Pavilion a450n PC Desktop
I too have a Asus CM5570 I love the machine; yet I have another SATA drive that I was very interested in installing in myself as a slave drive and a another CD drive to copy some music in the internal DVD...
If it's like the CMM570-AP002 I've seen, your system has enough spare SATA ports and power connectors for two additional drives. With SATA you don't have to worry about master/slave drives like you did with IDE; just plug each drive into a separate SATA port.
Installation is pretty simple and straightforward, and you can use the existing drives as guides. If it stops booting after installation, check the BIOS and make sure it's still trying to boot from the right hard drive. If you haven't done it before, consider looking up dedicated guides to drive installation and BIOS editing.
Feb 27, 2011 | ASUS Essentio Desktop with Intel Core 2...
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
I just bought a hard drive from ebay as a second drive its a western digital 250gb ide drive but my pc will not recognise it as a storage device but it installed the drivers! what am i doing wrong?
Hi:
often when you install a IDE driv ne that is as big as yours, you often need to run the WD installation software first. The easy way is to go to the WD website and download WD Data lifeguard tools program. you can try running it with that drive as a slave, or you can just install your new drive by itself, and go from there
Nov 18, 2009 | Western Digital WD2500SD Caviar RE EIDE...
Need to know what the pin placement is if i add another hard drive on the same ribon? whitch hd. is master and whitch is slave?
The hard drive that you have your operating system on is the master, and the one for storage is the slave. Normally. The slave is the secondary drive. Hope this helps
06castwo
Jun 12, 2009 | Western Digital Caviar 40 GB Hard Drive
Computer won't acknowledge new drive as master
press delete or F2 when you turn on your pc go into setup and change the boot sequence.
Mar 02, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard Drive Install gone bad!
Unplug the slaved hard drive.
Restart the computer. If you get the same results.
Pull out the cmos battery on the motherboard. Most look like shiny nickles, be carefull not to damage the board. Make sure you unplug the computer first and let it sit a minute or two afterwards before putting it back.
That will set the bios back to defaults and you should be able to get the computer up and running from there.
As far as slaving that drive to be used as extra storage, you might want to consider an external enclousure instead.
Best of luck.
Feb 24, 2009 | eMachines T3406 PC Desktop
Samsung SP0802N 80GB Slave
Go into the control panel. Press administrative tools. Select computer management. Under storage select disk management. Look for the hard drive. Make sure there isn't an additional partition on the drive. If there is you can change and delete partitions on this drive as well.
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
111 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
