Question about Brother IntelliFAX 4100 Laser Fax
We can send faxes with no issues but when we receive a fax that has multiple pages after the first couple of pages we get half pages, partial prin or blank pages. We were told it was a possible system board issue so we replaced the Brother 4100e with a new one and are having the same issue. Has anyone ever heard of this. I am leaning toward a possible line issue but not positive. Any help would be appreciated.
  • Brother Expert
  • 159 Answers
Is it pulling two pages at once? Sometime a machine will start to pull a sheet normally, then the page below it will get dragged along by the friction between the two sheets. One page's print gets divided between the two. If that looks like the case, pull out the paper drawer, remove the paper, and lightly sand the little rubber or cork pad at the front, then wipe the dust off with a damp cloth and let it dry. Before putting the paper back in, grasp the stack at one end, and "fan" the other, allowing air to get between all the sheets.
Get into the machine's Paper menu to see what size is programmed for the tray. If you have Letter size in there, but it's set for some other size, all kinds of feeding problems can occur, including false jams.
The paper feed roller is controlled by a magnet lever inside the right side of the machine. It should click once to start each sheet feeding. I've seen one Fax 4100e that clicked over and over, feeding extra sheets, just like you described. It turned out to be the system board. Worse yet, Brother had switched factories in mid-production of this model, and the replacement board they sent us fed paper just fine, but wouldn't do anything right on the phone line. Couldn't dial, couldn't answer. They sent another replacement, and it was exactly the same. Brother eventually broke down and sent a replacement machine.
Posted on Oct 06, 2010
  • 1 more comment
  • mddavis239 Oct 07, 2010
    Thanks but it is not feeding multiple sheets. We are looking into line issues with the VOIP.
  • Eric Sandbo Oct 07, 2010
    Does the fax machine have its DSL filter? If you're running VoIP over the phone lines, that sounds like a DSL connection. Lack of a filter on the fax could explain the problems with both systems.
    This is a company running Avaya VoIP and 600 employees. No dsl.
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Joe
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Faxing issue
To my knowledge, you can only fax multiple pages from the printer itself. Place the fax page on the glass, press "fax" ,then press "black" or "color" after doing this to all the pages, press "ok" They have now been sent. I am assuming that you have your phoneline connected correctly to the printer. You should be able to hear it on another phone extension when your fax modem dials.
Apr 05, 2009 | Canon PIXMA MX300 All-in-One Printer
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
Problems sending to a particular number
Try sending your fax to a lower baude rate to 14,000 bps, I had this problem before and I solved it by sending to a lower sending speed bacause the line was very noisey.
Mar 16, 2009 | Canon LaserCLASS Fax 710 Printer
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
390 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
