Question about Roper REX4634KQ Electric Dryer
Dryer does not heat - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 05, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
Hello there:
please try this
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Jan 19, 2010 | Dryers
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
Dryer not heating. Toubling fine.
hello there there are 5 different things that can majke your dryer not heat up please review these 5 things that i have provided
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 18, 2010 | GE Dryers
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
The dryer does not give heat
Hello there:
Proper Voltage
8574d88.jpg Heating Element
d5b5af3.jpg Thermal Fuse
77d6bd4.jpg Thermostat
Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Roper REX4634KQ Electric Dryer Logo
61 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
