Question about GE GSL25JFPBS Side by Side Refrigerator
Fan stalls on freezer side. starts and stops continuously, making a clicking noise, after a few hours we can forcibaly start the fan up again.
    Sergeant:
    Champion:
  • 351 Answers
Your fan motor is going bad . you need to replace fan and the board in back of refer
Posted on Oct 08, 2010
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Whirlpool American side by side fridge/freezer is making a clicking noise. Sometimes it lasts a few minutes and other times it can last over an hour. If I open the doors its stops and as soon as I close...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Whirlpool ED2FHEXN Side by Side...
My side-by-sdie has started to emit an intermittent rumbling noise on the freezer side. The noise continues for a few minutes at a time, goes off for another few, then resumes again. Is there a...
It's common problem. Freezer fan hitting over ice formation behind freezer. It is due to non defrost problem.
Keep thermostat temp must be 5 degree and check timer and thermostat are working properly. Unplug your fridge and after all defrost icing, start again. If still noise behind freezer, check fan leaves are broken. If so replace it.thanks.
Jan 31, 2011 | Kenmore 53642 / 53644 Side by Side...
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
There is a low pitched howling/humming noise coming from the freezer compartment. The noise is not constant but cycles on and off every 15 minutes. It will make the noise for a period of time then suddenly...
The evaporator fan motor likely needs replacing. The fan is located behind the rear panel in the freezer section. It may just be loose or rubbing but usually it just needs replacing. Here is a link that should help Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Nov 17, 2010 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker and water stopped working, hear a clicking sound. We tried cutting power and starting again, it stopped making the noise, but we still got no ice or water, and after a couple hours started making...
the sound from the icemaker is coming form the water solenoid valve, which needs to be replaced. if your frezer is cold then the fan is fine, most are switched to turn off when you open the door so you arent likely to see it running unless you set up a camcorder in your fridge :-)
Aug 14, 2009 | General Electric GSH25JSXSS Stainless...
Freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Dec 26, 2008 | Maytag MTB1891AR Top Freezer Refrigerator
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
