Question about HP Photosmart M527 Digital Camera
Flash I cannot for the life of me make the flash stop working. The light is way too bright making peoples skin look sickly. Am I missing a command that turns off the flash???
Top of the camera, lightning bolt like button. When you press it while the camera is on, it will bring up a menu, there should be an option in there to shut it off.
Posted on Aug 08, 2008
Can't take a picture without abundant light
Does it work okay in bright sunlight without a flash? If so, try changing the options to factory default.
Mar 23, 2010 | Olympus E-520 Digital Camera with 14-42mm...
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
Tip
How to convert video to flash flv,swf?
Video to Flash Converter
Video to Flash converter is the best video to flash software to convert the existing video to Flash video format FLV and SWF which is the first choice to add video to website and blog.And at the same time it automatically generates an HTML webpage embeded video to save programming work for Flash making newbies. With video to flash converter, you can convert almost all video formats: AVI, MPEG, MPG, Quicktime(MOV), WMV, M4V, ASF, MKV, RM, RMVB, 3GP, 3G2, DV, FLV, HD video to Flash on Windows XP, Windows Vista, and Windows 7.
Video to Flash converter allows you to edit your video before convert video to flash, like video clipping, cropping, merging, adding artistic effects(Gray, Old Film, Emboss), adjusting video brightness, saturation and contrast, sliding to make a playlist. The highpoint lies in its customize features that you can take audio & video settings, select a customize flash player with skinning control bar, add special effect, attach preloader for your output flash video.What's more, Video to Flash converter empowers you to add text/image to video, embed hyperlink in video and create a head and tail at the beginning and end of the flash files.
Key Functions of the Video to Flash Converter:
  • Transcode the existing video to Flash format for website:
    Convert AVI, MPEG, MPG, Quicktime(MOV), WMV, M4V, ASF, MKV, RM, RMVB, 3GP, 3G2, DV, FLV, HD video, AVCHD(MTS/M2TS), Flip video, QT, VOB, MOD, TOD video to Flash, FLV, SWF files and automatically embed video in an html webpage.
    The output flash video could be in HD format, with high quality, normal quality and low quality.
  • Edit Flash video with powerful editing features:
    Versatile editing functions to edit flash video:crop video to remove black bars and change video brightness, contrast, saturation, take video frame rate and bitrate, add effect(Gray, Old Film, Emboss), get multiple segments from source videos by clipping, merge multiple video clips into one file, slide multiple video clips into frame to make a video playlist.
  • Customize Flash video with a few mouse clicks
    Provide you with customize flash player with skinning control bar, many kinds of special effect and preloader. You can set your favorite color as a background, add text/image to video as watermark and embed an URL link in video. At the beginning and end of the video, add customize head and tail for Flash SWF video with special effect and background color.
System Requirements:
  • Processor:
    AMD® or Intel® processor
  • OS Supported:
  • Hardware Requirements:
    512MB RAM, Super VGA (800×600) resolution, 16-bit graphics card or higher
on Jul 06, 2010 | Computers & Internet
The flash is to bright i have a really bad picture at night... peoples skin is really white and so is almost everything else
Most cameras have a function where you can decrease or increase the brightness of the flash. I, too, had that problem on the built-in flash on the Nikon D40, so I toned it down to -1 power, which illuminated the subject but didn't wash out. Also, if you're shooting an external flash, try toning the ISO settings on the flash to a lower number or decreasing the power. Also, angling the flash away from the subject slightly helps a great deal.
Jul 07, 2009 | Sakar Digital Concepts Digital Camera and...
I can't figure out how to use my SB800 off camera with the D80 in command mode.
You can purchase a simple hot shoe mount slave or a pc corded slave. Do you know what a slave is? Most cameras have a flip flash on the camera. You can use this to fire your off camera flash. Most flip flashes are so low in power as compared to your SB800 that the flip flash will cause very little exposure effect to the image. Now there are things to consider, such as if you are outside in bright light a slave has more trouble detecting a flash. If you are indoors you need to at least have the off camera falsh localised to the flip flash and the slave in direct view of the flash. Some slaves are more sensitive than others. the great thing is with digital you can experiment all you want. Back in the day using film was costly, a lot of bracketing and guessing and time consuming. Why do you want the flash off the camera? What is your subject? I have usually found a bounce card on the flash or off a ceiling or wall effective for people. If you are lighting an indoor scene it is understandable to use off camera lighting.
Mar 12, 2009 | Nikon Speedlight SB-800 TTL Flash
Tip
Video to flash converter, convert video to Flash FLV SWF for website
$49.95
Doremisoft Video to Flash converter is the best video to flash software to convert the existing video to Flash video format FLV and SWF which is the first choice to add video to website and blog.And at the same time it automatically generates an HTML webpage embeded video to save programming work for Flash making newbies. With video to flash converter, you can convert almost all video formats: AVI, MPEG, MPG, Quicktime(MOV), WMV, M4V, ASF, MKV, RM, RMVB, 3GP, 3G2, DV, FLV, HD video to Flash on Windows XP, Windows Vista, and Windows 7.
Key features:
Convert AVI, MPEG, MPG, Quicktime(MOV), WMV, M4V, ASF, MKV, RM, RMVB, 3GP, 3G2, DV, FLV, HD video, AVCHD(MTS/M2TS), Flip video, QT, VOB, MOD, TOD video to FLV, SWF files and automatically embed video in an html webpage.
Provide you with customize flash player with skinning control bar, many kinds of special effect and preloader. You can set your favorite color as a background, add text/image to video as watermark and embed an URL link in video.At the beginning and end of the video, add customize head and tail for Flash SWF video with special effect and background color.
Have a Trial
It is for windows user, if you are mac user, please use Video to Flash video converter mac version
on Mar 15, 2010 | Computers & Internet
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Flash
Silly question as I am sure you have tried but try turning the Flash on permanently in the settings of the camera. Let me know if it works.
Nov 29, 2007 | Sony Ericsson K800i Cellular Phone
Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Oct 29, 2007 | Samsung Digimax S500 Digital Camera
Flash to bright
I have this camera. The only way I found to fix this was to tear off a strip of writing paper just a bit bigger than the flasher on the front, and then tape it over the flash. If you use writing paper (i.e. the stuff you use in school), it's thin enough for some light to come through, but stops the annoying problem of making everything too bright. I hope this helps!
Sep 24, 2007 | Vivitar ViviCam 3750 Digital Camera
HP Photosmart M527 Digital Camera Logo
54 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
