Question about Griffin Technology iTrip Auto with SmartScan FM Transmitter for Apple iPod
Need wiring color codes, cord pulled out. - Griffin Technology iTrip Auto with SmartScan FM Transmitter for Apple iPod
Form top to bottom, for the wires on the power connection side (right) Aqua (A), Brown (S), orange (LR), yellow (LG), black (G), red (L). The letters in parenthesis indicate the letter by the connection on the circuit board.
Posted on Jan 23, 2011
  • Jim Feb 01, 2011
    Do you have a diagram for the iPod connector side. Those wires pulled out on me.
I have an ipod 3 in 1 car kit for ipod model IP-QRFM88.The wires that are attached to the part that goes into my ipod all snapped and i want to solder them back on how do i do it
Posted on Sep 30, 2011
Here are wires from an iTrip Auto 2007 model.
iPod side below.
Power Plug side below.
Posted on Sep 25, 2012
  • Mike Sabo Sep 25, 2012
    The picture above is of an unaltered iTrip 2007 power side connection. It appears that the Green(left) and Violet(center) wires are mis-placed from the factory. The Violet attached at (G) and Green attached at (V) with the Blue(Aqua) attached to the (A) side as it should seem to be. If so then the correct placement for Violet is J3 and Green is J4 in the power plug. I would suggest checking both sides of this wire before reattaching wires incase yours is properly attached and not like the one pictured. .
  • 127 Answers
Munashe, here is a photo of my repaired itrip smartscan, there is also information about the color order and whyhttp://www.flickr.com/photos/26791657@N00/8016684580/in/photostream
Posted on Sep 23, 2012
  • Mike
    Mike Mar 10, 2014
    dead link
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
I need to change the power cord to my dryer to fit the outlet in my new residence. Is there any specific order to how the tabs hook to the dryer on the back? They aren't color coded.
If you are using a 3 wire cord the wires go exactly as you see them. The middle wire goes onto the middle terminal and the outside wires go to the outside terminals which one goes on which side doesn't matter.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside of the terminal block and I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Sep 04, 2009 | Frigidaire Dryers
I have a Kenmore Diswasher model. 587.15103801 - My question is - can I wire a 3 prong power cord to it? If so, what do I need to purchase? Thanks
The dishwasher SHOULD have a three prong cord, or be hardwired using using a 3 conductor electrical wire capable of handing 15 to 20 amps (12 or 10 gauge wire). If you desire to use a cord with a plug on the end, you can purchase a power tool replacment cord rated at 15 amps or higher from the hardware store (I have found power tool replacement cords to be very durable). Make sure you purchase one that is long enough the accomodate pulling the dishwasher out from under the counter, if required. The power cord is installed in a junction box behind the lower toe panel that's located directly below the door. The wire color coding is as follows:
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
Match the color wires with the wires inside the dishwasher junction box and twist together using wire lugs. Attach the ground wire to the appropriate ground lug.
If you have questions, please let me know. I hope this helps you.
Aug 27, 2009 | Dishwashers
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Griffin Technology iTrip Auto with SmartScan FM Transmitter for Apple iPod Logo
2,919 people viewed this question
Top Griffin Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
